headlights fogged from the inside anyway to fix 'em?
Old Jul 5, 2006 | 08:44 AM
I Like Hondas's Avatar
Default headlights fogged from the inside anyway to fix 'em?
My friend has a teg with fogged headlights. But it seems like its in the headlight. Does anyone know something about putting them in an oven????
Old Jul 5, 2006 | 08:49 AM
Uncle Willie's Avatar
Default Re: headlights fogged from the inside anyway to fix 'em? (I Like Hondas)
Dont leave them in their to long or they will melt...obviously. U could use a knife also to cut through some of the glue, then try and pull it apart.
Old Jul 5, 2006 | 08:55 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Get a cookie tray, lay some tinfoil down on it,
Put the lights in for around 6-8 minutes at 350,
just make sure you're watching them around the last few minutes.
Once they're done and out, gently pry apart the housing with a flathead,
have the metal clips off beforehand though, do the reverse for putting them back together.
Old Jul 5, 2006 | 11:09 AM
davidluko's Avatar
If there's water condensation in the inside of the headlight, you just need to seal the seam between the lense and grey plastic with some silicon sealant. Let the headlight dry out first before sealing it (the inside). There's no need to take them apart.
Old Jul 5, 2006 | 11:16 AM
jdm_bones's Avatar
Try a blowdryer!
imzjustplayin
Lighting
Jul 10, 2009 03:16 PM
dso
Acura TL, RL & ZDX
May 26, 2009 10:08 PM
Roybal 3
Aug 18, 2008 12:37 PM
SIKCAR
Honda S2000
Nov 21, 2005 04:20 AM
CRX7
Jul 3, 2002 07:29 PM
