Car stopped, check engine light, oil light, battery light, won't start.... HELP!!
Old Jul 5, 2006 | 08:24 AM
rayzian's Avatar
Default Car stopped, check engine light, oil light, battery light, won't start.... HELP!!
I was on the way to work when suddenly the car kind of jerked and lost all power and the CEL, oil and battery light all came on. I stopped and tried to start it but to no adue. Had to pay $50 to get it towed back home.
I remember reading threads where this happened to other people but I can't find them now, anyone know what happened? Damn this sucks...
Old Jul 5, 2006 | 08:26 AM
Loserkidwac's Avatar
Default Re: Car stopped, check engine light, oil light, battery light, won't start.... HELP!! (rayzian)
Need some more info...does it turn over or is completely dead when you try and start it? I'm assuming all the dash lights came on as if the car stalled out, correct, the oil light didnt come on and then the car died?
Old Jul 5, 2006 | 08:30 AM
SVOboy's Avatar
What's the code for?
Old Jul 5, 2006 | 08:34 AM
rayzian's Avatar
Default Re: (SVOboy)
Yeah the oil light, CEL and battery light came on. I don't know what code (didn't check), but I just reset the ECU fuse and the car starts up fine now. F*ck what a waste of $50...
I'm hearing that it could be my ignitor? I need to go to work but I don't know if I should take my car...
rayzian's Avatar
(double post)
Old Jul 5, 2006 | 08:39 AM
CRXBart's Avatar
Default Re: (rayzian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian &raquo;</TD></TR><TR><TD CLASS="quote">Yeah the oil light, CEL and battery light came on. I don't know what code (didn't check), but I just reset the ECU fuse and the car starts up fine now. F*ck what a waste of $50...
I'm hearing that it could be my ignitor? I need to go to work but I don't know if I should take my car...</TD></TR></TABLE>
I've never had a cel come on when an ignitor went out. They also gradually go out, not all at once. It is usually a low RPM miss, that developes over time to a full on non running car. BTW the Oil, and Batt, are always on when the motor isn't running, and the ignition is on.
Old Jul 5, 2006 | 09:10 AM
crx_88_si's Avatar
did u try to start it before you reset the ECU??
sounds like a bad ign switch.
Old Jul 5, 2006 | 03:50 PM
rayzian's Avatar
Default Re: (crx_88_si)
Ok.. umm.... the car seems fine now.. so I don't know exactly what the hell happened this morning, but what I do know is that I lost $50 bucks
I did get a code 17 when my dad picked me up from work using my car... VSS? I recently swapped guages but I don't know if that has anything to do with it..
Old Jul 5, 2006 | 03:52 PM
rayzian's Avatar
Default Re: (CRXBart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXBart &raquo;</TD></TR><TR><TD CLASS="quote">I've never had a cel come on when an ignitor went out. They also gradually go out, not all at once. It is usually a low RPM miss, that developes over time to a full on non running car. BTW the Oil, and Batt, are always on when the motor isn't running, and the ignition is on. </TD></TR></TABLE>
What do you suppose happened? It was exactly like this.. I took a left, shifted to second, hit the gas and then the car jerked and the CEL came on, and it slowly lost power (coulldn't even accelerate) until I shut it off and then it wouldn't start.
Oh yeah I keep getting confused about the oil & battery lights.. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_88_si &raquo;</TD></TR><TR><TD CLASS="quote">did u try to start it before you reset the ECU??
sounds like a bad ign switch.</TD></TR></TABLE>
Yeah, that's when the tow truck guy came and I was trying to get it to start... it wouldn't. Not until I got home and reset the ECU fuse... I should've done that on the street and it would've saved me $50... ARG..
Old Jul 5, 2006 | 03:54 PM
SVOboy's Avatar
Man, I was almost in your position today trying to start figuring out why **** wouldn't happen, after about 15 minutes I realized I left my ecu in the house, *shrug*
Mehbe it was the old main relay farting at you?
Old Jul 5, 2006 | 03:56 PM
rayzian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Man, I was almost in your position today trying to start figuring out why **** wouldn't happen, after about 15 minutes I realized I left my ecu in the house, *shrug*
Mehbe it was the old main relay farting at you?</TD></TR></TABLE>
I'm now almost certain this is what is giving me problems. I can't wait to replace it.
Old Jul 5, 2006 | 05:57 PM
CRXBart's Avatar
main relay or fuel pump. Check for fuel first but those are probable, or mabey a coil. One day I parked my car at my house to go in and grab something. Came out and my car was dead. The coil died at idle. ******* distributors.
Old Jul 12, 2015 | 03:04 PM
Codester2580's Avatar
This Just Happened to me. Battery Light Followed by Check Engine Light, then the front brakes LOCKED at 45/MPH. It is 07/12/2015 and my car is a --05 Honda Civic-- . That was not cool and almost caused a wreak if the person behind me didn't respond quick enough. Car was towed and will find out tomorrow 7/17/2015.
Old Feb 22, 2018 | 04:54 PM
Kyla Stevens's Avatar
Did it end up running after you reset the ecu fuse? How did you reset it? I tried to find it online. From what I understand, you remove the negative battery cable for about thirty minutes.. is that correct? My car just did the same thing with the jerking and the battery and oil light coming on. Now I can't get it to start.
Ayushistar
Dec 15, 2018 01:20 PM
vegas hoe
Transmission & Drivetrain
Jun 3, 2009 02:12 PM
nemeii
23
Aug 10, 2008 03:10 PM
fuzzymemoforshow
Honda Civic (2006 - 2015)
Oct 21, 2006 08:04 PM
