Help, snapped a valve cover stud!!!
Old Jul 4, 2006 | 06:22 PM
Si_chRis's Avatar
Default Help, snapped a valve cover stud!!!
So i was putting back my valve cover and one of the inner valve cover studs where the spark plug cover goes snapped off. Is this a big deal? will oil leak through the hole over a long period of time, it hasn't yet though, can i get a new stud from honda??
Old Jul 4, 2006 | 06:25 PM
-JSpecEk*9-'s Avatar
Default Re: Help, snapped a valve cover stud!!! (JDMaLLDAy050)
i did the same thing and i jus left it like that. oil hasnt came out jus dont leave it uncoverd.
byronl's Avatar
i snapped mine off too after doing my valve adjustment. Use an ez out and yea u can get that bolt from honda. It'll be around $5 though, that's how much i had to pay. Oil will leak later on, it did for me, get it fixed asap.
Old Jul 4, 2006 | 06:30 PM
Si_chRis's Avatar
Default Re: Help, snapped a valve cover stud!!! (byronl)
does the bolt that snapped on me screw into somthing else under the valve cover and does it have a hex shape to take it off like the 4 outer studs?
Old Jul 4, 2006 | 06:32 PM
byronl's Avatar
that bolt screws to the head under the valve cover. Well take out your valve cover and see if you can grab some pliers and twist it out if it's sticking out. If it does then ur in luck, if not like in my case then you'll have to use an ez-out or drill.
Old Jul 4, 2006 | 06:37 PM
Si_chRis's Avatar
yea, lets say u have ur valve cover on, it snapped right at the base of where the washer goes. it just broke off far enough for me to put on the rubber washer and it seals the hole but theres nothing holding it down except for my spark plug cover. i think i could pull it off w/ pliers but won't it be hard to take off?
Old Jul 4, 2006 | 06:48 PM
Si_chRis's Avatar
bump
Old Jul 4, 2006 | 07:21 PM
Si_chRis's Avatar
anyone else have this problem? is it alrite to just stick my rubber washer where it orignally goes. The only difference is i don't have a nut holding it down like the other three. Note: this is the inner stud near the spark plug wires, not the main 4 outer ones
Old Jul 4, 2006 | 07:28 PM
db8gsr_teg's Avatar
it wont leak oil but its better if you fix right away. im in the situation like you. broke it like 2 months ago and never fix it yet but im gonna fix by next week.
Old Jul 4, 2006 | 07:29 PM
db8gsr_teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMaLLDAy050 &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have this problem? is it alrite to just stick my rubber washer where it orignally goes. The only difference is i don't have a nut holding it down like the other three. Note: this is the inner stud near the spark plug wires, not the main 4 outer ones</TD></TR></TABLE>
just put on the washer and try to push the washer down a bit so it will hold. i did this and it never leak
Old Jul 4, 2006 | 07:32 PM
db8gsr_teg's Avatar
https://honda-tech.com/zerothread/1676944
Old Jul 4, 2006 | 08:15 PM
Si_chRis's Avatar
Default Re: (db8gsr_teg)
For mine, there is still like 2 lines of threading left for it to catch a little for the nut so i put the nut on but it usually comes off but if i be real careful it stays on top of the washer. Then after that, i put my spark plug cover on and it keeps the nut from sliding off the washer. I don't really want to take my valve cover back off because one of the studs for the main outer four( left top) came off of the head with the valve cover before. I looked at the threading in the head where the stud screwed in and it was messed up for 1 or 2 lines but luckily my stud screwed back in tight. Im just afraid if i take my valve cover off again, ill get the threading messed up on the top left stud or even snapping half the stud in the head, then ill be really screwed! so if i can leave it the way it is, ill do it but if im gonna fix it, im gonna have to take that chance AHHH
Old Jul 4, 2006 | 10:34 PM
b16adx's Avatar
Default Re: (JDMaLLDAy050)
Well if its one of the studs that holds the spark plug cover on all you gotta do is take the valve cover back off and a deep socket 10mm and remove the broken stud and replace....simple
Old Jul 5, 2006 | 01:00 AM
stripes777's Avatar
its a simple fix, but youll prob wanna fork out money for a new gasket and some honda bond. those things arent suppposed to be tightened too tight. just hand tight and youll be fine.
its like 3.50 at the dealer i think. i did it to mine also when isntalling a new cam seal
Old Jul 5, 2006 | 06:48 AM
JDM_teh_WIN!!'s Avatar
Default Re: (stripes777)
This is a B series engine right? That bolt you broke is replaceable. You need to remove the valve cover to access it.
The bolt holds down the cam plates. Remove it with a 12mm socket and torque it down to 21ftlbs.
My bet is you are gonna break 1 or more in the near future. I broke 1 and replaced it, then when I was tightening them down again I broke another one. LOL such a pain in the *** to remove the valve cover again. LOL.
Those bolts get streched out easily if you are removing your valve cover alot. No biggy.
Old Jul 5, 2006 | 07:48 AM
fmrprojects's Avatar
Default Re: (JDM_teh_WIN!!)
damm what are all you tightening it too, 30ft lbs? its only supose to be hand tight or 8 ft lbs. its a simple fix just get a new stud and bolt and remove the valve cover to replace it
Old Jul 5, 2006 | 08:00 AM
Default Re: (fmrprojects)
Oh yeah, make sure to put some oil on the threads before you replace it.
Old Jul 5, 2006 | 04:36 PM
Si_chRis's Avatar
Just replaced the stud. Whew, what a relief, through out the whole time i was replacing it, i thought i might snap half of the stud inside the head but luckily i didn't. I put honda bonda also around the gasket, sparkplug seals and the rubber washers along the top. Everything seems good now. Thanks for all the help!!!!!!
Old Jul 5, 2006 | 05:25 PM
EK tommy's Avatar
Default Re: Help, snapped a valve cover stud!!! (JDMEK-9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMEK-9 &raquo;</TD></TR><TR><TD CLASS="quote">i did the same thing and i jus left it like that. oil hasnt came out jus dont leave it uncoverd.</TD></TR></TABLE>
x2
liljohn850
Jun 5, 2009 04:23 PM
webbs2jzgte
Mar 10, 2009 09:32 PM
ShinotakuX
Mar 5, 2008 03:05 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
TeamTooQuick
May 21, 2002 05:23 PM
