Broken Rocker Arm Assembly Bolt
Broken off in the head, not poking out enough to grab it, what can/ought I do to try and remedy the situation?
Also, anyone got an 8 valver or d15z1 for sale,
I'm think, I might try it if I can borrow the tools, but otherwise I think I'm just fucked because the tools would be more than the engine and it's an awfully thing bolt and were it broke it's kind of domed so it might be hard to drill well,
From: I told you to wait in the truck in Texas, United States
You could try left handed drill bits
or conventional drill bits with a screw extractor..
http://www.mytoolstore.com/hanson/hanson.html
http://www.mytoolstore.com/hanson/extractr.html
Sometimes you can drill a hole in the bolt and
tap a torx-type bit into it and use it as an extractor..
Possibly..
It might be more of an "automotive specialty item"..
I got mine through Snap-On and really got reamed.....
Soak it with penetrating oil like P-B blaster and surround the area
you are drilling with grease to help catch the metal chips..
Also "center-punch" beforehand it so the drill bit stays centered in the bolt...
Good Luck bro..
Good Luck bro..
brendon.richey
Feb 25, 2013 04:16 PM
moleodonuts
19
Jan 10, 2005 02:07 PM
