civic ex 93 fuel pump testing
Old Jul 4, 2006 | 12:48 PM
inhms's Avatar
Default civic ex 93 fuel pump testing
Is there a way to check to see if the fuel pump is working right with out taking it out of the car?...thanks for the info...
Old Jul 4, 2006 | 12:58 PM
littleredcivic's Avatar
remove the fuel line from the fuel rail and turn on the key. if the ignition cylinder, ecu,relay and pump are working, fuel should have fuel coming out of the line. if not, you need to go backwards and find the bad part. you can also remove the back seat and manually apply power to the fuel pump and look for fuel.
Old Jul 4, 2006 | 01:40 PM
PLAN:B's Avatar
Default Re: (littleredcivic)
He is correct, however please disconnect the battery before doing so. Also, to check proper LPH, they have a tester for that at Napa.
pappasmurf
Nov 11, 2024 07:43 AM
ROGUE STATUS
Sep 1, 2012 05:57 PM
PapaMoose
60
Oct 13, 2011 01:46 PM
o2flow.net
Oct 1, 2006 08:55 AM
DC_andrew
Jul 11, 2004 07:57 PM
