H22 pistons in H23
Old Jul 4, 2006 | 10:39 AM
SethS585's Avatar
Default H22 pistons in H23
I was wondering if I could use factory H22 pistons in my H23 to bump up the compression.
Old Jul 4, 2006 | 02:13 PM
twistedbydezign's Avatar
Default Re: H22 pistons in H23 (SethS585)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SethS585 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if I could use factory H22 pistons in my H23 to bump up the compression.</TD></TR></TABLE>
yes, u'll want to use 4th gen h22 pistons though, 5th gen are floating, and jdm h22 pistons will give you higher compression than usdm h22 pistons, but both will give higher compression than your h23 pistons
Old Jul 4, 2006 | 07:09 PM
PrecisionH23a's Avatar
Default Re: H22 pistons in H23 (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">yes, u'll want to use 4th gen h22 pistons though, 5th gen are floating, and jdm h22 pistons will give you higher compression than usdm h22 pistons, but both will give higher compression than your h23 pistons</TD></TR></TABLE>
Just curious.... what type of piston to valve-clearance does this certain set-up give?
Wiseco has a 88mm h23 piston which is actually a TRUE h22a piston.... the piston actually stuck out of the deck by 25 thou.
Old Jul 4, 2006 | 09:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (Mr Soichiro Honda)
Old Jul 5, 2006 | 12:03 AM
Default Re: H22 pistons in H23 (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
Wiseco has a 88mm h23 piston which is actually a TRUE h22a piston.... the piston actually stuck out of the deck by 25 thou.</TD></TR></TABLE>
ill let you know when i get the crank in, im using an h22 block, jdm h22 pistons, f22b crank/rods
Old Jul 5, 2006 | 04:25 AM
But that isn't a h23 block with h22 pistons.
Old Jul 5, 2006 | 04:52 AM
PirateMcFred's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Just curious.... what type of piston to valve-clearance does this certain set-up give?</TD></TR></TABLE>
The piston to valve clearance on my engine that is effectively an H23 with H22 pistons sticking out .042" has plenty valve clearance even with large nonVTEC cams. Just be careful of retarding the exhaust cam.
And the H22block with F22B crank and rods IS for intensive purposes a H23 block. Same deck height for all F-series sans S2000 engines.
Pirate
Turbo EH2
May 13, 2008 09:45 AM
crxsi541
Jul 20, 2005 11:36 PM
machine4321
Sep 19, 2003 07:02 PM
H23A1LUDE
Jun 12, 2003 04:43 PM
LudeyKrus
Feb 11, 2003 10:30 AM
