Brake Booster problem
Old Jul 4, 2006 | 10:27 AM
EF_LSVtec's Avatar
Default Brake Booster problem
Replaced my brake booster with OEM replacement...Pedal pressure is good but considerable loss in braking power...like stepping on the brakes when the motor is off. Brake woes started after I installed ITB's...I wonder if the long hose from the booster to the intake manifold has something to do with it?
Old Jul 4, 2006 | 10:31 AM
pimpwagon's Avatar
Default Re: Brake Booster problem (EF_LSVtec)
put a gauge on it and check how much vacuum you have to the booster. x- reference that with a fsm or haynes.
Old Jul 4, 2006 | 10:59 AM
EF_LSVtec's Avatar
Default Re: Brake Booster problem (pimpwagon)
But braking power was fine after itb install...except it was mushy. Initially, pedal pressure was fine but was slowly losing pressure that's why I replaced the brake booster. Now brake pressure is good all throughout but no braking power...Like I said, it feels like the motor is off or something
Old Jul 4, 2006 | 08:55 PM
mahatma's Avatar
Did you adjust the booster rod to the same length as the original one was?
I can't see the longer vacuum hose being a problem....
Old Jul 4, 2006 | 09:13 PM
pimpwagon's Avatar
Default Re: Brake Booster problem (mahatma)
sometimes people mix up fuel line and vacuum hose. ive seen fuel lines pinch shut when used for vacuum purposes.
Old Jul 4, 2006 | 09:47 PM
EF_LSVtec's Avatar
I used the correct gauge and type of hose...with regards to the rod? I have to ask my mechanic...cuz he installed it for me. I'll replace the brake pads too just in case. The set that I have has been in the car for close to 2 years...though I hardly drive the car except for autocrossing....and joy rides
cityofcaterpillars
Jun 12, 2010 02:15 AM
slamLOWnBANGIN
11
Feb 19, 2010 03:55 AM
LsVTEC 510
Feb 14, 2006 11:02 AM
SlowVtecCrx
25
Jan 21, 2005 07:22 AM
