head swap
Old Jul 4, 2006 | 09:56 AM
91redef520stk's Avatar
From: The Big SD,IRIEMONT, kali kinds, united states
Default head swap
Can a d16z6 head bolt on to a d15b2 block, please let me know?
Old Jul 4, 2006 | 09:59 AM
SVOboy's Avatar
Yes.
Old Jul 4, 2006 | 10:02 AM
Default Re: (SVOboy)
your sure of this
Old Jul 4, 2006 | 10:10 AM
SVOboy's Avatar
Default Re: (91redef520stk)
Yes.
Old Jul 4, 2006 | 10:14 AM
pimpwagon's Avatar
on an otherwise stock d15b2 what would this yield as far as hp gains?
Old Jul 4, 2006 | 10:17 AM
Default Re: (pimpwagon)
im not going for that just want better power then i got now, and i have a d16z6 head i got for cheap
Old Jul 4, 2006 | 10:27 AM
pimpwagon's Avatar
exactly. i just would like to know how much more power...
Old Jul 4, 2006 | 10:32 AM
watever i can get
Old Jul 4, 2006 | 10:33 AM
pimpwagon's Avatar
no. im asking the more knowledgeable people how much more power your head swap will give.
Old Jul 4, 2006 | 10:35 AM
ludesrv's Avatar
You will have in the 115-120hp range, maybe less. You need more then just the head. You need IM, dizzy, ecu, gotta run the ODB1 and VTEC wiring. It's more work then the gain is worth unless you are planning on going better in OBD1. If you are just looking for a quick gain with no money, I'd get a D16A6 or SOHC ZC, or even just run MPFI. MPFI alone is about a 10hp gain on the D15B2, that and they scream alot more after that if you have an intake. I shaved 2 seconds of my 1/4 mile by going from D15B2 to SOHC ZC haha.
JJ's civic's Avatar
2500 hp more i dunno
slpnz6's Avatar
Noticeable amount... but nothing thats going to blow your mind.. you can do a search and calculate what your compression will be and hp gains as well..
Old Jul 4, 2006 | 01:20 PM
slpnz6's Avatar
Default Re: (ludesrv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">You will have in the 115-120hp range, maybe less. You need more then just the head. You need IM, dizzy, ecu, gotta run the ODB1 and VTEC wiring. It's more work then the gain is worth unless you are planning on going better in OBD1. If you are just looking for a quick gain with no money, I'd get a D16A6 or SOHC ZC, or even just run MPFI. MPFI alone is about a 10hp gain on the D15B2, that and they scream alot more after that if you have an intake. I shaved 2 seconds of my 1/4 mile by going from D15B2 to SOHC ZC haha.</TD></TR></TABLE>
listen to this man... he knows...
Old Jul 4, 2006 | 03:49 PM
Default Re: (slpnz6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slpnz6 &raquo;</TD></TR><TR><TD CLASS="quote">Noticeable amount... but nothing thats going to blow your mind.. you can do a search and calculate what your compression will be and hp gains as well..</TD></TR></TABLE>well it will be more then my stock dx at least, im also going to be runnning the 4spd tranny 2 until further notice
Old Jul 5, 2006 | 05:02 PM
wat tranny would be best for this?
Old Jul 5, 2006 | 05:10 PM
SVOboy's Avatar
Well, the "Best" tranny would be the one with the shortest gearing, lsd is nice too,
Anyway, I think the zc tranny is the shortest stock d series tranny.
Old Jul 5, 2006 | 05:19 PM
how much do those go for?
Old Jul 5, 2006 | 05:31 PM
pinecone's Avatar
Quite a bit since they are from japan and usually only come on swaps that you buy.
Try and find a Si tranny. 89-91 Si.
Old Jul 6, 2006 | 11:17 AM
Default Re: (pinecone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pinecone &raquo;</TD></TR><TR><TD CLASS="quote">Quite a bit since they are from japan and usually only come on swaps that you buy.
Try and find a Si tranny. 89-91 Si. </TD></TR></TABLE>YEAH I THINK THATS WAT I WAS ORIGNALLY GONNA GET.
Old Jul 6, 2006 | 11:50 AM
ludesrv's Avatar
If you are doing alot of highway and care about MPG, use the 5spd HF tranny. You want good pep and gas mileage, DX is your tranny. You want fast acceleration with short gears and horrible highway, use the Si. I wouldn't bother with a ZC tranny, little bit longer gears the Si. If you want good highway mileage and peppy. Get a Si tranny and replace the 5th gear with the 5th out of a DX or HF, you will yeild good mileage on that 5th. I'm planning on DX 5th gearing my Si tranny.
Old Jul 6, 2006 | 12:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">If you are doing alot of highway and care about MPG, use the 5spd HF tranny. You want good pep and gas mileage, DX is your tranny. You want fast acceleration with short gears and horrible highway, use the Si. I wouldn't bother with a ZC tranny, little bit longer gears the Si. If you want good highway mileage and peppy. Get a Si tranny and replace the 5th gear with the 5th out of a DX or HF, you will yeild good mileage on that 5th. I'm planning on DX 5th gearing my Si tranny.</TD></TR></TABLE> do you know anybody thats got one?
Old Jul 6, 2006 | 12:09 PM
crxnj's Avatar
Default Re: head swap (91redef520stk)
Actually it will be about the same or slower Unless you have vtec working..(Meaning an ecu with vtec fuel and timing maps,and vtec wire(s) ran)
The reason its gonna be slower without vtec working is because you'll be on low cam all the time,,and not to mention you'll be using the same ecu
Old Jul 7, 2006 | 07:32 AM
Default Re: head swap (Mr.speaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.speaker &raquo;</TD></TR><TR><TD CLASS="quote">Actually it will be about the same or slower Unless you have vtec working..(Meaning an ecu with vtec fuel and timing maps,and vtec wire(s) ran)
The reason its gonna be slower without vtec working is because you'll be on low cam all the time,,and not to mention you'll be using the same ecu</TD></TR></TABLE>im gonna be running the p28 ecu
Old Jul 7, 2006 | 10:42 AM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91redef520stk &raquo;</TD></TR><TR><TD CLASS="quote">im gonna be running the p28 ecu</TD></TR></TABLE>
Old Jul 7, 2006 | 12:35 PM
wat would be a good set of headers for my mini me
