Wiring JDM 4gen fogs?
Old Jul 4, 2006 | 08:31 AM
evolvedAP1's Avatar
Default Wiring JDM 4gen fogs?
im wanting to buy some jdm fogs for my 4gen, my question is how do i wire them up to work without the oem fog switch? can i wire them up to just any ol switch?
Old Jul 4, 2006 | 08:38 AM
evolvedAP1's Avatar
and yes i've searched just still so confused...
Old Jul 4, 2006 | 08:54 AM
TruNinja619's Avatar
Default Re: (evolvedbb2)
you can be like me and do this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">So a few months ago, I did the Daytime Running Lights mod on my 4th gen. I used a foglight wiring kit b/c it made life much easier, despite costing about $20 I believe. So the switch that it came w/ was okay for the job, but I wanted to take it a step further and make a switch for it, one that will fill one of the holes on my center console. So I bought a fog light switch for a 7th gen civic ('01-'05) and it manage to fit flush. here's some pixs of it:
Qveon's Avatar
Get a relay, pole 30 goes to the fogs +, pole 87a goes to 12v+, then ground the fogs. pole 85 goes to the switch then to 12v, ground pole 86.
Old Jul 4, 2006 | 08:55 AM
evolvedAP1's Avatar
Default Re: (TruNinja619)
ok but what about wiring the fogs up for power?
Old Jul 4, 2006 | 08:59 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evolvedbb2 &raquo;</TD></TR><TR><TD CLASS="quote">ok but what about wiring the fogs up for power?</TD></TR></TABLE>
I put that wire w/ the positive wire on the fuse box, under the hood....
if you wanna make life MUCH easier.... get a foglight wiring kit... already wired up and all you have to do is make the connections....
Old Jul 4, 2006 | 09:01 AM
evolvedAP1's Avatar
where can i get the kit?
Old Jul 4, 2006 | 09:02 AM
evolvedAP1's Avatar
and dont really understand all that pole this pole that...
Old Jul 4, 2006 | 09:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evolvedbb2 &raquo;</TD></TR><TR><TD CLASS="quote">where can i get the kit?</TD></TR></TABLE>
I got mines at pepboys, but i'm sure you can go to other automotive part stores and get it as well...
Old Jul 4, 2006 | 09:18 AM
evolvedAP1's Avatar
hrmm sounds like a good idea. how did you wire your switch with that plug hooked up?
Old Jul 4, 2006 | 10:52 AM
cifer6425's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evolvedbb2 &raquo;</TD></TR><TR><TD CLASS="quote">and dont really understand all that pole this pole that...</TD></TR></TABLE>
once you get the relay and look at it, you will understand.
Old Jul 4, 2006 | 11:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evolvedbb2 &raquo;</TD></TR><TR><TD CLASS="quote">hrmm sounds like a good idea. how did you wire your switch with that plug hooked up?</TD></TR></TABLE>
I cut off the switch that came w/ the fog light wiring kit.. and matched each wire (switch, power, and ground) to its designated connector on the switch I am using now...
Old Jul 4, 2006 | 07:26 PM
bboixtc's Avatar
its not that serious. just get the 4 pin rc-2201 relay from honda, any automotive store or junk yard, and attach it to the socket thats already under your steering column wrapped in blue tape, hook up your oem fogs to the oem plugs, and if you have a 92-93 lude, ur socket for the switch is tucked right inside your driver side tweeter cover and if its 94-96, your switch socket is right by the radio near your shifter. then there should be 6-8 wires or so connected to the socket you connect to the switch. cut the socket off, get a electronic voltage tester thing, and see which wires are ground and hot, and basicaly you sodder the wires to the switch.
good luck
guywitaDA
Apr 17, 2007 05:04 PM
bboixtc
Apr 19, 2006 12:11 AM
[Ennis_D]
Jan 20, 2005 11:57 AM
JDMjames
Feb 23, 2004 05:58 AM
jdmintegra1994
Oct 4, 2003 10:55 AM
