suspension bolt rusted help.
Old Jul 4, 2006 | 05:27 AM
campbuds's Avatar
Default suspension bolt rusted help.
My LCA bolt to the rear trailing arm is appears to be rusted. It won't break lose. Any recommendations on good ways to remedy the problem?
Old Jul 4, 2006 | 05:37 AM
maxum17ft's Avatar
Default Re: suspension bolt rusted help. (campbuds)
lots of heat and pb blaster, and good luck
Old Jul 4, 2006 | 05:42 AM
MrRealityman's Avatar
PB blaster, it puts WD-40 to shame. get it at walmart. spray your bolt liberly with it. go have a drink. come back. put your socket on the bolt and pound on that socket with a hammer to help brake the rust seal. then try to remove the bolt. if its still stuck. spray it again and go have another drink. and so an and so forth.
i cant stress how much of a pain it is to have that bolt brake. avoid braking it if you can. i went to get a trailing arm of a car at a junk yard once and someone had put red thred lock on all the bolts. i had to cut the part off the car and go home and drill out all the bolts.
Old Jul 4, 2006 | 05:43 AM
eda6's Avatar
Default Re: suspension bolt rusted help. (maxum17ft)
spray it with pb blaster let it sit for 5 minutes, tap it with a hammer, spray more pb blaster, wait about 30 minutes and it try loosening it again.
Old Jul 4, 2006 | 07:24 AM
slkleltlclh's Avatar
pb blaster and snap-on
Old Jul 4, 2006 | 09:52 AM
CASTUDILLO01's Avatar
heat up bolt and if that dosent work torch it out and replace it with a new bushing and bolt very common in ny state due to salt in the winter
Old Jul 4, 2006 | 10:04 AM
Sleepy_Red_hatch's Avatar
Default Re: suspension bolt rusted help. (CASTUDILLO01)
some suspension bolts are way too stubborn, theese are grade 8 bolts, and with my impact (1000 ft-lb) all i managed to do was round off the head, get another assy from somewhere and replace yours
Old Jul 4, 2006 | 10:17 AM
ekcivic9's Avatar
i feel bad for the people up north
i sprayed pb blaster 3 days before i did my suspension job... the bolt came apart like butta.
Old Jul 4, 2006 | 10:20 AM
prison_snitch's Avatar
man my bolt came off when i grabbed my brakes with my hands and used my leg to push on the ratchet. just use LOTS AND LOTS of pb plaster all over the place. it breaks the rust free. use a breaker bar also. or put a scissor jack under your ratchet and jack the ratchet up
Old Jul 4, 2006 | 11:17 AM
Skadaloz's Avatar
my **** is seized up...if i cant get it loose...ima have to cut that bitch out and drill it....i want to put on my ****** tein SS suspension on but i cant cuz that **** is all seized up
Old Jul 5, 2006 | 04:52 AM
campbuds's Avatar
I resorted to cutting it (i didn't want to) but nothing else was working.
hammered out the bushings and will just need to get new ones.
unhappy_idle
May 16, 2006 09:22 AM
thw_goalie
Suspension & Brakes
Mar 29, 2006 11:08 AM
flip b18b
Jun 28, 2004 10:31 PM
GoQkRaCeR
Apr 24, 2004 05:40 PM
Allstar
Nov 11, 2002 11:14 PM
