b18a1 wont rev over a certain point prolly around 3grand
Old Jul 4, 2006 | 12:14 AM
ilikejesus's Avatar
Default b18a1 wont rev over a certain point prolly around 3grand
i just bought a 90 ef with a b18a1 swap and it wont rev over a certain point what can this be?
Old Jul 4, 2006 | 08:58 AM
crx_88_si's Avatar
its in LIMP mode, check the ecu for codes.
Old Jul 4, 2006 | 09:23 AM
ilikejesus's Avatar
Default Re: (crx_88_si)
were whould i check the ecu for codes? and could it just be the wrong ecu?
Old Jul 4, 2006 | 09:26 AM
mikespike2's Avatar
Default Re: (ilikejesus)
Did it give you a check engine light?
Old Jul 4, 2006 | 09:31 AM
ilikejesus's Avatar
Default Re: (mikespike2)
yeah its on
Old Jul 4, 2006 | 09:34 AM
crx_88_si's Avatar
lift up the carpet on the pass side floor (where the feet go) and count hte blinks that come from that little clear hole in the cover.
Old Jul 4, 2006 | 09:51 AM
ilikejesus's Avatar
it goes one then brake then 6 kinda fast
Old Jul 4, 2006 | 09:57 AM
crx_88_si's Avatar
ok, when you first turn the car on (while watching this LED) it will blink once to indicate it has power and works, then blinks 6 times.? if that is the case code 6 = Coolant Temperature Sensor.
this is the trouble shooting for it
Old Jul 4, 2006 | 10:09 AM
ilikejesus's Avatar
ok i will try that and thank you!
drew2
Dec 3, 2005 11:51 AM
hondaZvic
Apr 21, 2004 06:26 PM
BigMig
May 10, 2003 06:01 PM
crxtreme27
Aug 9, 2002 11:57 AM
RedRacerCivic
Dec 6, 2001 11:45 AM
