Restoring fuel efficiency
Old Jul 3, 2006 | 11:14 PM
garyc17's Avatar
Default Restoring fuel efficiency
I am getting very bad fuel efficiency on my B18c5. Will retarding my cam timing back to zero degree give me better mileage? I know I will be losing power for sure, but the horrible fuel mileage is unbearable. I am getting only 300km every full tank. My B18c5 is stock except for H22 injectors, excedy clutch kit and cam sprockets. I am running a PowerFC as well. Should I retard the cam timing back to stock and lean out my tuning?
Old Jul 4, 2006 | 09:06 PM
b19coupe's Avatar
Default Re: Restoring fuel efficiency (garyc17)
Tuning with a wideband on a dyno would be your best bet. Just guessing at what settings to run is a recipe for trouble.
Old Jul 4, 2006 | 09:28 PM
H-PIMP's Avatar
Default Re: Restoring fuel efficiency (b19coupe)
Injectors and power FC are probably the culprits. Get a wide band and tune your car properly, it's sounds like your just dumping fuel.
Old Jul 4, 2006 | 09:56 PM
Reid's Avatar
Global Moderator
Was your car tuned with the Power FC?
Old Jul 4, 2006 | 10:28 PM
mtber's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">I am getting very bad fuel efficiency on my B18c5. Will retarding my cam timing back to zero degree give me better mileage? I know I will be losing power for sure, but the horrible fuel mileage is unbearable. I am getting only 300km every full tank. My B18c5 is stock except for H22 injectors, excedy clutch kit and cam sprockets. I am running a PowerFC as well. Should I retard the cam timing back to stock and lean out my tuning?</TD></TR></TABLE>
Get your car street tuned
Old Jul 5, 2006 | 01:30 AM
rG`'s Avatar
rG`
^ Tuning required
&lt;-- 540km / tank
Granny shifting FTW!
Old Jul 5, 2006 | 04:54 AM
Eva01's Avatar
Tuning is the key. I run H22 injectors and usually get around 33-35 mpg on the hwy.
kikeh22
Sep 22, 2004 10:40 AM
ASSASSIN
Sep 1, 2004 11:52 AM
jeremy.
Oct 2, 2003 06:27 PM
GraphiteAccord
Sep 1, 2002 04:03 AM
VTECHGSR
Oct 30, 2001 01:44 PM
