Question about dyno??
Old Sep 20, 2004 | 09:18 AM
kikeh22's Avatar
Default Question about dyno??
I got a lot of stuff in my car but this is actually the ones that you can tune...
Vafc
Cam gears
Fuel pressure regulator
and of course ,timing
I'm just wondering if there is any specific order to tune them (Ex. cam gears first,vafc second etc etc)?
Old Sep 20, 2004 | 11:41 AM
Finest's Avatar
Default Re: Question about dyno?? (****h22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****h22 &raquo;</TD></TR><TR><TD CLASS="quote">IVafc
Cam gears
I'm just wondering if there is any specific order to tune them (Ex. cam gears first,vafc second etc etc)? </TD></TR></TABLE>
Set your timing and fuel pressure to near stock settings. Make a baseline run. Read the graph for spikes or irregularities. Check your A/F logs. Find out where you're running rich or lean. Adjust your AFC accordingly to compensate (lean out the rich areas, richen up the lean areas) If you're N/A, keep timing near stock, or advance at the most a few degrees. Keep in mind your cam gear changes also indirectly affect ignition timing too.
Try to keep changes to a small percentage (around +/- 5%) Run it again and read the graph and A/F logs. That's about it!
Old Sep 20, 2004 | 11:50 AM
9SECQTR's Avatar
nicely said
Old Sep 21, 2004 | 07:31 AM
kikeh22's Avatar
Default Re: Question about dyno?? (Finest)
SO YOU ARE TELLING ME THAT I SHOULD MESS WITH THE VAFC FIRST AND THEN WITH THE SPROCKETS(DEGREES)??
tHIS IS HOW I GET IT,IS THIS CORRECT??
1. STOCK TIMING AND FUEL PRESSURE= BASELINE RUN
2.ADJUST FUEL PRESSURE
3.WORK WITH THE VAFC(RICH,LEAN,VTEC CROSSOVER POINT ETC)
4.AND THE LAST ONE,WORK WITH THE CAM GEARS
AFTER ALL THOSE 4 STEPS SHOULD I GO YO THE SECOND STEP,THIRD STEP ETC UNTIL I GET BEST TUNE??
THANK YOU FOR YOUR HELP
Modified by ****h22 at 8:43 AM 9/21/2004
Old Sep 22, 2004 | 10:40 AM
kikeh22's Avatar
kikeh22
13
Sep 29, 2004 05:00 AM
kikeh22
Sep 20, 2004 09:55 AM
radeon
Aug 6, 2004 08:10 PM
Edwin
May 13, 2003 05:55 PM
