surprisingly went up to 10 lbs on the boost gauge!!
Old Jul 3, 2006 | 08:58 PM
3rdgenLS's Avatar
Default surprisingly went up to 10 lbs on the boost gauge!!
info. integra ls; greddy turbo kit; greddy s bov; tuned on crome; 310cc;
my boosted ls for is set up and tuned on 7 lbs of boost until today when it went up to 10 lbs on my sw boost gauge. it never done this the first 9 weeks i've been boosted.
through my searched on the archived some people say is a gauge failure, but are there any other possibilities? the only thing i've done recently is turned the purple top of the bov the other way exactly 18 degrees.
tia
Old Jul 3, 2006 | 09:13 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: surprisingly went up to 10 lbs on the boost gauge!! (3rdgenLS)
probably just boost creep you never noticed before
Old Jul 3, 2006 | 09:18 PM
3rdgenLS's Avatar
thanks for the reply! you think so? i'm pretty sure it never happened before..
Modified by 3rdgenLS at 11:03 PM 7/3/2006
Old Jul 3, 2006 | 10:42 PM
OMG B16's Avatar
I vote for boost creep also.
Old Jul 3, 2006 | 11:30 PM
3rdgenLS's Avatar
Default Re: (OMG B16)
thanks!
Old Jul 4, 2006 | 05:19 AM
sc4dr's Avatar
Default Re: (3rdgenLS)
Would that be from an insufficient wastegate?
Old Jul 4, 2006 | 06:15 AM
B16Civic93's Avatar
Default Re: (sc4dr)
let me ask you, when you see 10psi is it when it first builds boost it spikes to 10psi then drops down to 7? or does it hit 10 and stay there? or does it depend on which gear you are in? What type of boost controller are you running? the stock wastegate spring on the 18g is 5.5 psi. if you give us some more details on what is going on we can help better determine why it is doing this
Old Jul 4, 2006 | 12:10 PM
3rdgenLS's Avatar
Default Re: (B16Civic93)
it pretty much stays on 10psi until i changed gear from 2nd, 3rd to 4th gear. i'm not running a boost controller.
sc4dr
is an internal wg
Old Jul 4, 2006 | 04:49 PM
wantboost's Avatar
Who is Mr Robot?
so its stays at 10psi in 2nd and drops down in the rest of the gears? its boost creep. the wastegate cant handle the flow in 2nd gear
Old Jul 4, 2006 | 05:04 PM
quicksilver1689's Avatar
i ♥ snails
internal wastegate is probly the problem source.
Old Jul 4, 2006 | 09:40 PM
3rdgenLS's Avatar
Default Re: (quicksilver1689)
it goes up to 10psi in 2nd through 4th gear not sure on 1st and 5th gear.
i don't know why would the wastegate wouldn't be able to handle the boost because i never messed with it and i never had a problem with boost creep the first 9 weeks i've been boosted.
i appreciate the all the help!
Old Jul 4, 2006 | 11:04 PM
3rdgenLS's Avatar
i'm going to try to buy a boost controller to see if that would help.
Old Jul 5, 2006 | 07:12 AM
wantboost's Avatar
Who is Mr Robot?
boost controller wont help a shitty wastegate
Old Jul 5, 2006 | 09:30 AM
spooncivic1's Avatar
greddy kits will almost never boost spike or creep...so that probably isnt the problem...
and how are you running 7psi when the wastegate is set at 5.5 factory?
Old Jul 5, 2006 | 10:13 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: (spooncivic1)
you can thread the wastegate rod to make a ghetto boost controller.
ive seen the greddy internal wg creep plenty of times
Old Jul 5, 2006 | 11:21 AM
Default Re: (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">you can thread the wastegate rod to make a ghetto boost controller.
ive seen the greddy internal wg creep plenty of times</TD></TR></TABLE>
well that is most likely the problem. they probably arent made to adjust the actuator arm...it would be better to get a MBC
or you can try to port the turbine housing and run a 2.5" downpipe to help boost creep
edited
Old Jul 5, 2006 | 11:25 AM
wantboost's Avatar
Who is Mr Robot?
i think you mean the turbine housing. ill try to find pics of a greddy setup i was impressed by
Old Jul 5, 2006 | 01:59 PM
3rdgenLS's Avatar
damn you f-i people knows your $h1t..
i bought the turbo kit used and the guy did say he was running 7lbs of boost.
when i got it tuned it was reading 7.2psi at 4k-4500 rpm and quickly drops. at 5k rpm i'm getting about 5.8psi and at 6k-7k rpm i'm getting only about 4.8psi.
Old Jul 5, 2006 | 02:51 PM
wantboost's Avatar
Who is Mr Robot?
yup, boost creep
Old Jul 5, 2006 | 05:24 PM
97gsrki's Avatar
boost creep. I had a greddy kit on a stock gsr motor and around 7500-8000 it would creep up to 10 psi just as you said.
Old Jul 5, 2006 | 08:05 PM
mike93boost's Avatar
i was running holding 10psi fine onmy greddy 15g.. using a turbosmart mbc.. also ported the hell out of the wastegate flapper hole. it was tiny as hell. and i also turned the nut on the wastegate actuator rod on full turn. steady at 10psi after that...
Old Jul 5, 2006 | 08:06 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (mike93boost)
porting the wastegate flapper hole in the single best thing you can do
Old Jul 5, 2006 | 09:06 PM
Weq's Avatar
Weq
make sure u have not developed a hole/pinhole/leak in ur wastegate line. Mine did and it will act as a 'bleed' valve and up the boost.
Old Jul 6, 2006 | 11:17 AM
3rdgenLS's Avatar
Default Re: (Weq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Weq &raquo;</TD></TR><TR><TD CLASS="quote">make sure u have not developed a hole/pinhole/leak in ur wastegate line. Mine did and it will act as a 'bleed' valve and up the boost.</TD></TR></TABLE>
i'd checked.
i'd just picked up a hallman mbc, hope it'll fix the boost creep.
Old Jul 10, 2006 | 03:32 PM
3rdgenLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">i was running holding 10psi fine onmy greddy 15g.. using a turbosmart mbc.. also ported the hell out of the wastegate flapper hole. it was tiny as hell. and i also turned the nut on the wastegate actuator rod on full turn. steady at 10psi after that... </TD></TR></TABLE>
just installed a hallman mbc and it didn't do anything with the boost creep. so then i tried the nut turning on the wastegate actuator rod and it seems that it worked. but now i'm boosting 8psi and i have the boost controller at the minimum.
