diagnosing ABS on a 92 Si?
Old Jul 3, 2006 | 04:55 PM
xxmastermindxx's Avatar
Default diagnosing ABS on a 92 Si?
my ABS light is on, car usually starts up and drives for about 10 seconds before it turns on. anybody have any idea how to diagnose it? its a 92 prelude Si. i read in a magazine how to check the code like you would the engine light, but i forgot what it was. thanks guys for any help.
Old Jul 3, 2006 | 05:03 PM
Ludefun's Avatar
Default Re: diagnosing ABS on a 92 Si? (xxmastermindxx)
Well, I'll throw out the easy fix, as it's about all I have expertise for. I had a problem similar to that, and it was just my brake fluid being low. Put some in and it worked fine.
Old Jul 3, 2006 | 05:18 PM
i checked both resovoirs and they seem fine, full to the top. ill check again though, thanks. any other ideas?
Old Jul 3, 2006 | 06:26 PM
MilanoLude's Avatar
check the sensors, I had a similar problem that unfortunately lead me to pay for a diagnostic test and was told I had a loose sensor...
Old Jul 4, 2006 | 12:01 PM
im checking the sensors now and the fluid levels again, thanks.
anyone else know anything about this?
Old Jul 5, 2006 | 02:10 AM
upallnite's Avatar
Default Re: (xxmastermindxx)
I have a trouble shooting guide for this at home. If I don't answer back by tonight remind me with a PM. It might be late when I post it.
Old Jul 5, 2006 | 02:25 AM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: (upallnite)
The only car I ever had ABS on was my 4 door GSR My ABS light turned on and all it was was one of my tires was Low!!! check your tire pressure..this might not be the problem but it be cool if that's all it was.....it was in my GSR
Old Jul 5, 2006 | 06:33 PM
jamieson's Avatar
Default Re: (I got the CD5 Jeebies!)
Here comes the worst case scenario game. Why? Because I'm living it right now. ABS light.
I need AT LEAST a modulator and probably a pump. $2k in parts. And damned right I'm going to shell it out (this is without labor btw, that would be another $400).
Old Jul 5, 2006 | 10:50 PM
Default Re: (jamieson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamieson &raquo;</TD></TR><TR><TD CLASS="quote">Here comes the worst case scenario game. Why? Because I'm living it right now. ABS light.
wow I wouldn't amost buy a new one for that amount
Old Jul 6, 2006 | 04:05 AM
syntax.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxmastermindxx &raquo;</TD></TR><TR><TD CLASS="quote">my ABS light is on, car usually starts up and drives for about 10 seconds before it turns on. anybody have any idea how to diagnose it? its a 92 prelude Si. i read in a magazine how to check the code like you would the engine light, but i forgot what it was. thanks guys for any help.</TD></TR></TABLE>
You Do check the ABS code the exact same way you pull the code for the check engine light. The only difference is that the cel will flash the stored codes until you remove the jumper, the abs will only cycle the codes twice. Pull the abs code and post it up and we can tell you what is malfunctioning. Best case scenario is that a wheel speed sensor is fubared, worst cas is pump motor overrun/modulator malfunction etc. . . those are very pricey to fix.
I took out my abs lightbulb
Old Jul 6, 2006 | 04:08 AM
soundbomber's Avatar
Default Re: diagnosing ABS on a 92 Si? (syntax.)
hmm, that sucks, i just had an abs modulator and pump out that i tossed out, you could have had it.
Old Jul 6, 2006 | 07:28 AM
syntax.'s Avatar
Default Re: diagnosing ABS on a 92 Si? (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">hmm, that sucks, i just had an abs modulator and pump out that i tossed out, you could have had it. </TD></TR></TABLE>
Did you use the prop. valve and master cylinder from a non abs S prelude?
Old Jul 6, 2006 | 11:16 AM
yeah, hardlines for the front brakes too
Old Jul 6, 2006 | 05:42 PM
ahh well thats cool
no the cars ABS components are all original, never did anything with them.
is there any chance having two diff kinds of tires would mess with it? i dont know the exact sizes right now, but my rear tires are winter and the front two are regular, front are wider too. the back tires got jacked up so i have the winters on there till i buy new ones. but the ABS light didnt come on till like a month later.
DillyD
Sep 16, 2010 07:37 PM
94~GSR
Sep 30, 2005 10:33 PM
Old_Honda
Jun 5, 2004 10:57 PM
tintin11
Jan 27, 2004 01:30 PM
vain
Apr 13, 2003 12:40 PM
