Why don't they make camber kits in Japan?
I noticed that there is no such thing as a JDM camber kit.
One mechanic told me that camber kits are bad for dialing in more negative camber. He said that it would remove the play in the drive shaft and if you bottom the suspension it can damage the tranny and drive shaft. Bascially the drive shaft will run out of room to move and bind into the hub and tranny. He also mentioned that it adds load to the bearing and will prematurely wear them out.
Is this true?
He said if you want more camber, lower the car and put in stiffer spring to prevent bottoming.
I wanted to get an adjustable front upper control arm, but now I think it might be a bad idea.
Please share your views.
Thanks,
CB
Is this true?
Thanks,
CB
becuase japanese use camber for race only(to put negative camber). they dont use a camber kit to correct the negative camber.
Is this true?
He said if you want more camber, lower the car and put in stiffer spring to prevent bottoming. *bottoming got nothing to do with stiffer spring, if u lower too much on a long stroke shock, it still bottom out. one possible solution is to get a height adjustable pillow mount.
Thanks,
CB
Is this true?
Thanks,
CB
Anyone,
CB
There's nothing wrong with using a camber kit to dial in more negative camber. I'm running kits front and back with no problems. I think you'd only run into some issures if you run too much negative camber.
Lowering the car would increase negative camber too but it will be uneven all around. As for springs, if you're on stock suspension, I doubt you'll bottom out unless you nail a speedbump at like 25+ mph or a huge pothole.
[Modified by SpecR_EK, 9:40 PM 4/18/2002]
then japanese camber kit is good.(and also never hear those problems)
but one thing u have to know. although, camber kit can increase your cornering speed, but it also reduce your brake power when u negative too much(less contact area of the tire).
It still interesting that Spoon, Toda, Jun, Mugen, and many others don't make a camber kit. I wonder why?
Am I wrong about this?
CB
CB
it really depends on which shop/race car you're looking at
while most of the listed companies don't make their own camber kits, they do adjust camber for track purposes. often, they use other camber kits such as ASports.
I've never heard of this being an issue, both for race cars and street cars.
You should be fine.
You should be fine.
correct too much. On my car I would correct about 1-1.5 degrees and
everytime I press the gas down the inboard joints would separate and break.
You can only stretch the axle out so far.
eTec
19
May 21, 2002 04:51 AM
ESCALVANTE
Jan 31, 2002 10:36 AM
