bushing toll ????
i went to a shop to see how much they would want to push bushing and he said that there's a tool for that and you dont need a press. anyone ever hear the before i'm trying to do my lower control arms. and if you have can you tell me the name of the tool and about how much it cost.?
Modified by joeny12985 at 9:17 PM 7/3/2006
A similar tool, although MAYBE different in size, is a ball-joint removal tool, or ball-joint remover.
Otherwise, in my garage, I'd probably name it a "screw push pop thingy"...to be technical.
I'm going to call it the "More time for beer" toy.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joeny12985 »</TD></TR><TR><TD CLASS="quote">anyone know the name of the tool?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vegaskurt »</TD></TR><TR><TD CLASS="quote">*cough*
https://honda-tech.com/zerothread/1677637
*cough*</TD></TR></TABLE>
he said lca <U>not</U> trailing arm.
if you dont have a press just drill holes around in the rubber then pull the center metal out and cut the sleeve with a hacksaw and pry and bend it, it will pop out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">
if you dont have a press just drill holes around in the rubber then pull the center metal out and cut the sleeve with a hacksaw and pry and bend it, it will pop out</TD></TR></TABLE>...if you don't destroy the ring in the process...
Its called a ball joint press, I think auto zone will rent you one. Harbor freight also sells them for much less but use at your own risk. For the LCA's just take them off and go to a place that has a press. $40 later you should be done.
the only place i was sent to by people said they dont' have the right tool and the other place out here that is a ricer shop wants $75 minual
theYBLEGAL
Suspension & Brakes
11
Mar 22, 2015 09:12 PM
mortificationrock
May 4, 2010 05:54 AM
