Need a big favor from a helms manual owner
Old Apr 18, 2002 | 07:29 PM
shadowdawn's Avatar
Default Need a big favor from a helms manual owner
I believe one of the 2 "speed sensors" on my automatic have gone bad, because of permenant code 70 and blinking d4 (and perfect driving tranny). If anyone has a helms and could scan the pages including removal/servicing of anykind of the sensors on an automatic 99 integra. Mabye I can inspect them myself before paying $380 on tuesday to the dealer to do it for me.
I appreciate any help you guys can give on this.
Old Apr 24, 2002 | 08:15 PM
shadowdawn's Avatar
Default Re: Need a big favor from a helms manual owner (shadowdawn)
I actually only need information on how to replace the "main driveshaft speed sensor" That part is coming tomorrow.
[Modified by shadowdawn, 1:02 AM 4/25/2002]
Old Apr 24, 2002 | 08:32 PM
Ramnix's Avatar
Its pretty easy, just locate it, then there is a 6mm bolt that hold it in there, remove that, then pull out the sensor along with the rubber o-ring, and then just push the new sensor into the hole with a new o-ring. Lightly tighten the bolt, but not too hard. And then you will need to reset the TCM ( tranny control module )
to do this... on the fuse box in the engine compartment remove the backup fuse for 10 second, but make sure you have your radio code, then install is back, and there you go
this is all from the 96 factory manual, I think the reset sequence is the same for the 99 since both are obdII
Old Apr 24, 2002 | 09:07 PM
shadowdawn's Avatar
Default Re: Need a big favor from a helms manual owner (Ramnix)
just wondering if you knew the exact location of it, or relative location and if you have to oil up the sensor or anything special... and this is the driveshaft speed sensor we're talking about correct... just to be safe can you list any other sensors on the tranny that could be replaced? So I don't get them confused when I attempt this myself.
Old Apr 24, 2002 | 11:10 PM
94autotegLS's Avatar
New User
Just saw your website Damn your car is clean, your car is exactly what i want to have someday
Old Apr 25, 2002 | 12:08 AM
shadowdawn's Avatar
Default Re: Need a big favor from a helms manual owner (94autotegLS)
Thanks :D she's my baby.
94 IntegraLS
Sep 7, 2013 06:18 PM
skata89
Aug 28, 2007 07:52 PM
sixtodc2
Jun 5, 2007 12:12 AM
team 15
Jan 10, 2007 10:47 PM
BG Performance
13
Sep 20, 2005 08:49 PM
