H2B swap
Old Jul 3, 2006 | 06:41 AM
TheAccordGuy's Avatar
Default H2B swap
I know a guy that makes custom mounts and I was wondering if I could do the h2b swap in my accord. As long as I had some good customs mounts. I'm also wondering if the engine would fit correctly anyone know for sure. I raced my friends del sol on a track of course with my accord h22 and beat him barely, because of his short gears. I would love to have these extra short gears as well.
Old Jul 3, 2006 | 08:47 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: H2B swap (TheAccordGuy)
What the hell is an H2B
Old Jul 3, 2006 | 09:27 AM
teamlegacy's Avatar
Default Re: H2B swap (213374U)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 213374U &raquo;</TD></TR><TR><TD CLASS="quote">What the hell is an H2B</TD></TR></TABLE>
Old Jul 3, 2006 | 11:02 AM
philadd's Avatar
Default Re: H2B swap (teamlegacy)
H2B is a kit that allows an H series motor to bolt up to a B series tranny. The kit was designed to eliminate the axle problems that owners had after swapping an H22 into a Civic or Integra. With the ability to retain the B series tranny, owners were able to keep the axles at correct angles and positions, and the swap itself would eliminate the need for custom tranny mounts.
The kit is NOT designed for Accords. It will NOT work in Accords. You would have the same axle problems that the kit was designed to eliminate in Civics and Integras.
Your friend's Del Sol is also lighter than your Accord. If all you want is shorter gears, then you should look into changing your final drive.
Old Jul 3, 2006 | 12:26 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: H2B swap (philadd)
Very interesting... never heard of it Then again, I generally stick to my Accord so anything involving a B-Series is pretty alien to me
Old Jul 3, 2006 | 07:39 PM
cambopheonix56's Avatar
Learn something new everyday.
t3/t4turbo
Feb 8, 2012 01:12 AM
yoRt
20
Mar 26, 2008 08:31 PM
TheAccordGuy
Jul 3, 2006 07:56 AM
Nov 17, 2005 06:38 AM
c27_accord
Jul 26, 2005 05:51 PM
