Engine rebuild - is this head trash?
Old Jul 3, 2006 | 01:15 AM
s_18's Avatar
Default Engine rebuild - is this head trash?
I am in the prosess of rebuilding a D16Z9 (same as Z6) for a friend of mine.
One of the bearing surfaces on the head seems a bit iffy...
I'm not sure if it can be used, or if we just have to throw it away and get a new one.
I'm not sure if it's possible to tell by these pictures, but I had a real hard time getting the camera to focus.
I might have to try and get some better ones.
The cam cap has the same sctatch pattern. Cam seems perfect. Not sure what to make of this.
Old Jul 3, 2006 | 03:56 AM
Syndacate's Avatar
Wow, nvm, I'm not thinking straight...
Old Jul 3, 2006 | 08:10 AM
hatchi's Avatar
Default Re: Engine rebuild - is this head trash? (s_18)
bring it to a machine shop and see if its still usable
Old Jul 3, 2006 | 08:13 AM
mattssi's Avatar
That is some heavy scarring. IF that is a cam journal then it might not be reusable because you do not use bearing there so you cannot adjust for removed material by using a thicker bearing. But you will have to just check at a machine shop. It is hard to tell from that pic how deep the scarring is.
koczeka
43
Apr 5, 2014 04:57 AM
chikin pickle
Jun 11, 2010 01:02 PM
91-lsvtecsi
Dec 8, 2008 04:27 PM
Mighty
Jan 11, 2004 03:57 PM
omega11855
Oct 27, 2003 07:36 AM
