MSD blaster coil
Any members on the board using one of these blaster coils on your R? Wondering if it is worth it or not for my car. I might be able to pick up one really cheap and thought why the hell not.
I will be visiting the dyno soon to tune the cam gears and VAFC. I have basically a lot of bolt-ons in the car currently. Would the MSD blaster coil unit increase power at all? Should i forget about it and stick with the stock ignition coil? Thanks for you input.
yea, i tried a msd 6a with coil 3, and it run suck in street of willow. i have to put back stock in order to run right.
btw, low end is better tho.
I never tried the MSD stuff but I did try the Jacob Electronic ignition system and I had to change back to stock two days later because the car would not run properly (stalled everywhere). As mentionned, the stock ignition system is more then enought for mild to moderate engine modification.
