HELP! Low compression in 1 cylinder! running out of ideas.
Old Jul 2, 2006 | 06:11 PM
Lamchop0000's Avatar
Default HELP! Low compression in 1 cylinder! running out of ideas.
i just swaped in stock d16a6 motor. and it ran shitty so i did a compression test.
cylinder:
1-160psi
2-155psi
3-170psi
4-80psi
last nite i put a few drops of oil in cylinder 4 and re-did the compression test and the numbers bumped up to about 120psi. so i assume it was the rings, i then pulled out the pistons and cleaned out the rings and put them back in.
they look fine by the way, no broken rings or ring lands. all pistons and rings look almost identical. i cant see why #4 would be durasticly lower then the rest!
before and after the cleaning.
and the compression numbers are still the same! im exhausted with this problem. someone help me pinpoint this problem.
Old Jul 2, 2006 | 06:20 PM
CASTUDILLO01's Avatar
Default Re: HELP! Low compression in 1 cylinder! running out of ideas. (Lam.N)
check to see if you don't have any bent valves in cly#4
Old Jul 2, 2006 | 06:27 PM
Default WHaaaaaaaaaaaaat?!
here are some pics of cylinder 4 before installation
is a bent valve obvious? do those look normal?
thanks, need more help.
Old Jul 2, 2006 | 06:28 PM
Default Re: WHaaaaaaaaaaaaat?! (Lam.N)
OH ****, is this a bent valve?! that red circle... compared with the green ones...
Old Jul 2, 2006 | 06:29 PM
nappyroots827's Avatar
Default Re: HELP! Low compression in 1 cylinder! running out of ideas. (CASTUDILLO01)
thats not how you left your ring end gaps is it? in that configuration?
Old Jul 2, 2006 | 06:31 PM
Default Re: HELP! Low compression in 1 cylinder! running out of ideas. (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">thats not how you left your ring end gaps is it? in that configuration?</TD></TR></TABLE>
nope, i did it according to helms
Old Jul 2, 2006 | 06:42 PM
ok, yea that valve doesn't look like its seating right...I would take it out and check it for straightness...also while there out, if they seem okay, i would lap them to get a good seat...other than that, it can't really be anything else but a warped head or block?? Or your old head gasket could have blown out
Old Jul 2, 2006 | 06:46 PM
jacoop86's Avatar
before ripping apart your engine agian, try a leakdown test, see where those gases are escaping from.
Old Jul 2, 2006 | 06:50 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: HELP! Low compression in 1 cylinder! running out of ideas. (jacoop86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacoop86 &raquo;</TD></TR><TR><TD CLASS="quote">before ripping apart your engine agian, try a leakdown test, see where those gases are escaping from.</TD></TR></TABLE>best idea yet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">ok, yea that valve doesn't look like its seating right...I would take it out and check it for straightness...also while there out, if they seem okay, i would lap them to get a good seat...other than that, it can't really be anything else but a warped head or block?? Or your old head gasket could have blown out</TD></TR></TABLE>
will do. i used a new headgasket.
ok, i will try that out... this damn engine is killing me. thanks for the quickness guys.
Old Jul 2, 2006 | 07:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">i would lap them to get a good seat...</TD></TR></TABLE>
BTW, what does Laping them mean?
Old Jul 2, 2006 | 07:32 PM
MANDO6669's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">OH ****, is this a bent valve?! that red circle... compared with the green ones...
okay i thought you had a problem with cyl4???? not three..
best bet is a leak down test i guess.
Old Jul 2, 2006 | 07:40 PM
Default Re: WHaaaaaaaaaaaaat?! (MANDO6669)
that is cylinder 4 with the red circle. i circled the green ones for comparison...
Old Jul 2, 2006 | 08:06 PM
MANDO6669's Avatar
hehehe ... it was looking at it wrong ....
Old Jul 2, 2006 | 08:33 PM
Default Re: (MANDO6669)
lappin the valves means using a grinding compound on the valve seat and the face of the valve where it meets the seat, you can get all the stuff from any auto store, u need grinding compound and these stupid little looking suction cups on wood, haha, you just put the grinding compound on the valve and seat, press the valve shut and spin the valve back and forth to grind an even surface for the valve to seat on....its a pretty gay process, takes a while with 16 valves, but its worth it...
Old Jul 2, 2006 | 10:33 PM
Default Re: (nappyroots827)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nappyroots827 &raquo;</TD></TR><TR><TD CLASS="quote">lappin the valves means using a grinding compound on the valve seat and the face of the valve where it meets the seat, you can get all the stuff from any auto store, u need grinding compound and these stupid little looking suction cups on wood, haha, you just put the grinding compound on the valve and seat, press the valve shut and spin the valve back and forth to grind an even surface for the valve to seat on....its a pretty gay process, takes a while with 16 valves, but its worth it...</TD></TR></TABLE>
ahhh i think i've seen those... so this is a poor mans way of repairing a tweaked valve?
Old Jul 3, 2006 | 08:01 AM
Default Re: (Lam.N)
its not the poor mans way of fixing a valve by any means, it the valve is bent, it NEEDS replaced....all good machine shops do this, its just a way to ensure a valve is seeting correctly, especially after replacing the vavle and/or seats
Old Jul 3, 2006 | 08:16 AM
oh i knew that, haha. thanks boss
Old Jul 3, 2006 | 05:18 PM
91civicEX's Avatar
it could just be your cylinder is worn out. if the compression went up its probably not a bent valve. a ghetto way of checking is take the cam out of the head and fill the combustion chambers with water to see if one leaks a lot. i think a few drops is normal. also those valves that u circled. one may not be bent. it could just be different size margins on them from one wearing faster? do you have micrometers available? i suggest you measure the cylinder in about 4 points and compare it to the others.
Old Jul 3, 2006 | 07:02 PM
Default Re: HELP! Low compression in 1 cylinder! running out of ideas. (91civicEX)
whatever it is... im going to do a leak down test before i do anything stupid again.
Old Jul 6, 2006 | 01:54 AM
leak down test, and valves were bent, air was just rushing out of the T/b.
i found 4 intake valves that were bent, and big thanks to 91civicEx for supplying me with replacements!
that bent valve was pretty obvious after i rotated the valve a few times.
also lapped the valves
tomorrow i will put the engine back together and do a compression test and i hope i will get good numbers. and fire her up!
Modified by Lam.N at 3:23 AM 7/6/2006
Old Jul 6, 2006 | 02:06 AM
crxnj's Avatar
EDIT---I need to learn how to read...
Old Jul 6, 2006 | 07:51 PM
91civicEX's Avatar
hopefully u only gotta put it together one more time haha. good luck man
Old Jul 6, 2006 | 08:28 PM
cyl compression is:
1=155
2=152
3=160
4=165
the once weakest cylinder is now the strongest haha...
and yeap she Runs!!! but i need to time the ignition and that would be it. she is running a bit hot i think, my fan came on for the first time. maybe theres bubbles in the cooling system.
now its time to see the state referree! big thanks to everyone!
Old Jul 6, 2006 | 09:22 PM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N &raquo;</TD></TR><TR><TD CLASS="quote">cyl compression is:
1=155
2=152
3=160
4=165
sweet, a sucess story
