Full-Race Crossmember Compatibility w/SOHC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 »</TD></TR><TR><TD CLASS="quote">front engine mount isnt needed.
done deal buy it</TD></TR></TABLE> Oh yes it is. I didn't run a front engine mount on my SOHC for three mounts, in that three months I managed to kill the clutch, one other mount, and the tps from constantly hitting the firewall under hard acceleration.
have u tried throwing in some poly inserts and not running a front mount?...it does suck that they dont make a d-series compatible one though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stefndogg »</TD></TR><TR><TD CLASS="quote">have u tried throwing in some poly inserts and not running a front mount?...it does suck that they dont make a d-series compatible one though
</TD></TR></TABLE> Well inserts would be nice, but it is still not enough piece of mind. I know with all four of my mounts, two of them being custom Jim-Fab pieces that when I hit the gas, the chassis moves with the motor, not that motor moves into the chassis. I love the FR bar for clearance, but I don't love the fact that modification would be neccessary to run it for my setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lam.N »</TD></TR><TR><TD CLASS="quote">weld one on.</TD></TR></TABLE> Allrighty then, now time to turn this over to the Fabrication kids.
I know Innovative's x-member comes with provisions for the front mount, but if you can get a good deal on the full race go for it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote"> Oh yes it is. I didn't run a front engine mount on my SOHC for three mounts, in that three months I managed to kill the clutch, one other mount, and the tps from constantly hitting the firewall under hard acceleration.</TD></TR></TABLE>
I'll 2nd that
I'll 2nd that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 rex »</TD></TR><TR><TD CLASS="quote">Change the inserts in your mounts and you will be fine.
All b series are using 3 mounts. My motor hardly moves at all.
yes and all your mounts are basicly solid...
i would never run without a front torque mount....and i have inserts..
now i have the innovative mount with a basicly solid front mount for my SOHC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster »</TD></TR><TR><TD CLASS="quote">
Isn't the idea with inserts to make your mounts basically solid? Maybe I'm missing something here.
Isn't the idea with inserts to make your mounts basically solid? Maybe I'm missing something here.</TD></TR></TABLE>
inserts still have alot of room for movement it is by far not even close to being solid. even hasport mounts have some movement.
inserts still have alot of room for movement it is by far not even close to being solid. even hasport mounts have some movement.</TD></TR></TABLE>
I realize they move, but no where near like stock. A solid bushing is no different whether it's on a d series or a b series.
Si2See
Apr 12, 2008 12:12 PM
the soL that could
Apr 23, 2006 08:36 PM
the soL that could
Mar 1, 2006 12:04 PM
