Do all 6th gen coupes' clocks NOT light up?
Old Jul 2, 2006 | 03:00 PM
UGAmazing's Avatar
Default Do all 6th gen coupes' clocks NOT light up?
I've wondered this for a long time. My 02 coupe, my friend's 99 coupe, and my other friend's 2000 coupe all have a problem with the clock above the cd player not lighting up. It's just a regular little lcd screen, only visible until about 7:00, and then it's impossible to see the time. At first I thought it may just be our cars, but then I asked a few more people, and they said their clocks don't light up either. They didn't even put a clock on the cd player display to counter this problem. I find it hard to believe that Honda can forget something so...simple?
So what's the deal?
Old Jul 2, 2006 | 03:03 PM
bushrat's Avatar
Default Re: Do all 6th gen coupes' clocks NOT light up? (UGAmazing)
That would be called a burnt out light bulb. Do a search and you'll find what you need to replace it.
Cheers
Old Jul 2, 2006 | 03:55 PM
UGAmazing's Avatar
Awesome, thanks.
Do these things burn out easily/often? My friend who bought his 2000 accord new, said he can't remember his ever working. Strange!
Old Jul 2, 2006 | 04:00 PM
accordselux's Avatar
Me Gusta History
Default Re: (UGAmazing)
that could also be a fuse then if it's always been not working...
Old Jul 2, 2006 | 04:41 PM
BuCxLuXoRX2o0o's Avatar
Default Re: (accordselux)
more then likely you just have to replace the bulb. its like 4-5 bucks at the dealer
Old Jul 2, 2006 | 06:06 PM
Legendaryyaj's Avatar
Default Re: (BuCxLuXoRX2o0o)
like everyone else said, its either a fuse or a burnt out bulb.
The clock bulb is notorius on the 6th gen for being burnt out so thats why it may seem odd. Mine was blown on my 6th gen too. I thought maybe it just didnt have a light at first.
Old Jul 2, 2006 | 06:30 PM
AnAccordIsForever's Avatar
Default Re: (Legendaryyaj)
I guess we have enough participation to create a 6th-gen-burnt-clock-bulb club!
yeah its the bulb. its really simple to change it... I changed it on mine and for a friend who has the same model.
the only other one that has died on me yet is the shift column light bulb (for AT) and the cruise control button light.
Old Jul 2, 2006 | 08:17 PM
xxkevo's Avatar
any instructions on how to replace it? thanks!
Old Jul 2, 2006 | 09:46 PM
Heat's Avatar
Default Re: (xxkevo)
To take the clock out, take a look at step four in these instructions:
http://www.handa-accessories.c...d.pdf
Then, from a different thread:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02 accord &raquo;</TD></TR><TR><TD CLASS="quote">
... There is an indentation in the back cover for the bulb. You will be able to unscrew it without removing any covers. </TD></TR></TABLE>
The cost for the bulb from the dealer is something like $1.50. It's supposed to be easy to change, I haven't personally done it since my clock bulb is still going strong ('99 LX).
For what it's worth, the entire clock assembly with hazard button is ~ $20 or so, I had to replace the entire unit once after I messed up the clip on the back while unplugging it.
Old Jul 2, 2006 | 10:38 PM
02 accord's Avatar
My clock bulb burned out too. I replaced it with an LED, which cost me ~$0.20 compared to $1.50 at the dealer; and I know the LED will last forever, unlike the oem bulbs. Same goes for the cruise control light. The green bulb went out, and the dealer wanted $12 for it. I replaced that with another LED.
Old Jul 3, 2006 | 04:18 AM
Default Re: Do all 6th gen coupes' clocks NOT light up? (02 accord)
http://gwfweb.com/honda/pages/01clock.htm
http://www.superhonda.com/foru...52791
Old Jul 3, 2006 | 09:39 AM
georgeda's Avatar
These bulbs are ON whenever the ignition is on. It is not connecterd to the dash lights. So these bulbs burn out faster because they have been lit as long as the ignition was on, day or night. Stealer is the only place to buy them . . . guess why
Old Jul 3, 2006 | 10:00 AM
F23Coupe's Avatar
Default Re: Do all 6th gen coupes' clocks NOT light up? (georgeda)
Hm, that is a faulty design I think. Why have it light up even in daylight? I mean some people do put limo tint on their cars and the clock might not be visible then but still, these bulbs only last a few years at the most. I had mine replaced under warranty but it should last about as much as other interior lights. At 74k miles and 6 years, all of my other interior light bulbs are still good! Heck, even my headlights lasted close to 45k miles I think.
Old Jul 3, 2006 | 10:41 PM
Topnotcheez's Avatar
That appears to be the case in Acura TL's (wifee's 2001 TL) as well.
Old Jul 3, 2006 | 10:44 PM
accordinglyevil's Avatar
mine burnt out too. tried replacing it, but it never turn on again now i lost the bulb holder for the light.
Old Jul 4, 2006 | 09:34 PM
10nelyboi's Avatar
i had the same problem when i bought mine 02 SE, i bought a replacement bulb on ebay, at first it didn't work either, it scared me so i emailed the seller and asked for another bulb, and thanks god its work. u should try it, it's only 5 bucks, worth the try
Old Jul 4, 2006 | 09:40 PM
02 accord's Avatar
Default Re: (10nelyboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10nelyboi &raquo;</TD></TR><TR><TD CLASS="quote">u should try it, it's only 5 bucks, worth the try </TD></TR></TABLE>
Only 5 bucks? You can get it at a dealer for $1.50.
pitpul
Jun 30, 2018 01:18 AM
Nerz206
Apr 4, 2011 02:28 PM
B16Civic93
Dec 5, 2009 10:31 AM
rhd
Jun 27, 2005 08:12 AM
Rydaddy
Jul 6, 2003 04:58 PM
