Car dies immediately after startup - randomly!
Old Jul 2, 2006 | 02:38 PM
drumminforev's Avatar
Default Car dies immediately after startup - randomly!
b16a2 with 40k miles.
Occasionally, i will turn my car on and it will sputter out quickly and die. Usually if i wait 15 seconds and try again it will be fine. One time this happened, it would not turn back on. So i replaced the ignition coil, cap, rotor, plugs, and wires and the car started up fine.
Now the car sputters out and dies the say way. Its only been 2 weeks since i replaced all that ****. I think this time it is a fuel problem. Sometimes i wont hear the fuel pump prime for two seconds. That is usually when it will sputter out. Why would the fuel pump not prime sometimes?
Main replay? bad pump?
Old Jul 2, 2006 | 02:47 PM
littlegreenb18's Avatar
Default Re: Car dies immediately after startup - randomly! (drumminforev)
I think you were on the right track with ignition, doesn't really sound like a fuel pump to me. Your problem sounds similar to when i had a bad ignitor. if you have a Haynes manual and a multimeter, test your ignitor(aka ignition control module). hope this helps
Old Jul 2, 2006 | 03:44 PM
byronl's Avatar
ur main relay
Old Jul 2, 2006 | 11:35 PM
Dilly's Avatar
Default Re: Car dies immediately after startup - randomly! (byronl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by byronl &raquo;</TD></TR><TR><TD CLASS="quote">ur main relay</TD></TR></TABLE>
Old Jul 6, 2006 | 09:19 PM
Default Re: Car dies immediately after startup - randomly! (dillywong)
Its my main relay. I verified this by listing and feeling the relay when the car would not start. Nothing. So I will resolder the connections and off I go
Old Jul 6, 2006 | 10:28 PM
Dilly's Avatar
Old Jul 6, 2006 | 10:40 PM
Mohsin's Avatar
just re-solder the joints that have a crack around it, I had to re-solder 3 joints and no problems after a year
djw19842005
Sep 9, 2009 10:45 PM
crazyimport
Sep 2, 2008 09:22 AM
spettinger
May 25, 2005 11:46 AM
lawlerlaw
Nov 16, 2004 01:25 AM
