screws stripped out
2-3 mounths ago i did my motor swap b18b in my crx and i was going to replace the cap and rotor but the screws on the rotors were tight and they stripped out how could i fix this thanks
Grab them really tightly with some vice grips and try to spin them out, dremel a line on the head for a flathead, or just plain grind the head off and grab the stump that's left with the vice grips.
Oooh, I did that. I grabbed mine with pliers or smacked something bigger in than was meant to, then I went to the hardware store with the dizzy to find a replacement, good luck. You can prolly drill it out, also.
maybe cut the rotor so you can get to the bolt with a vise grips. or you could dry drill it out make sure you go straight you don't want to strip those threads.
Draggin99Si
Sep 5, 2003 06:43 PM
