my timing bet snapped on me!!
Old Jul 2, 2006 | 11:55 AM
97gSrkId88's Avatar
Default my timing bet snapped on me!!
what are the chances my valves are bent? i really don't want to pull the head to find out either. should i just replace the belt and hope for the best or should i check the head first?
Old Jul 2, 2006 | 12:09 PM
vuong916's Avatar
Default Re: my timing bet snapped on me!! (97gSrkId88)
check and save youself some money
Old Jul 2, 2006 | 12:19 PM
dohcMONSTER's Avatar
Default Re: my timing bet snapped on me!! (vuong916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vuong916 &raquo;</TD></TR><TR><TD CLASS="quote">check and save youself some money</TD></TR></TABLE>
Old Jul 2, 2006 | 01:11 PM
qfast817's Avatar
Default Re: my timing bet snapped on me!! (dohcMONSTER)
were you still diving it or were you stoped?
Old Jul 2, 2006 | 01:41 PM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: my timing bet snapped on me!! (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">were you still diving it or were you stoped?</TD></TR></TABLE>
and what rpm were you at
Old Jul 2, 2006 | 06:54 PM
jared99's Avatar
Default Re: my timing bet snapped on me!! (BOLO-FTW.)
My guess would be that you have bent valves. My timing belt broke just starting up the car. After putting the new one on, I went about one minute and the check engine light came on. A compression test showed a bent valve on cyl#3. Now, I would probably just replace the valve. Back then, I chose to just do a head swap. Cost me about $120 and fixed the problem. But I'm assuming yours is the GSR from your s/n, so it would be cheaper for you to just replace the valve than to do a swap unless you can find a head for cheap.
I have a writeup somewhere on how to replace the head if you haven't done it before.
Old Jul 2, 2006 | 07:12 PM
LordAphotic's Avatar
if traveling faster than idle... chances are pretty damn good you bent valves. but the severity depends on the rpm you were going....
dont put the timing belt on just to find out your gona have to take it off again and do lots of work.... just do it all now. that way you have a new headgasket too....
what kind of engine? b18b or b18c?
Old Jul 2, 2006 | 11:35 PM
calxtreme's Avatar
It's interesting cuz my timing belt snapped on me last week. I was going about 70 on the freeway. Towed it back, replaced belts and water pump, now my car runs fine.
Old Jul 2, 2006 | 11:38 PM
Fat Chick Magnet's Avatar
just buy a new b16 head and slap it on your gsr block it will save you more money.
turboedsupe
Mar 9, 2010 07:04 PM
DBAl
Jun 4, 2007 06:54 PM
swindler86
14
Oct 25, 2005 09:38 PM
skeematic
Nov 24, 2004 10:53 PM
eeyore357
Sep 24, 2004 06:09 AM
