Transmission noise. Whats the culprit?
Old Jul 2, 2006 | 10:55 AM
crxisok's Avatar
Default Transmission noise. Whats the culprit?
When the clutch is in the noise goes away. I believe the transmission is making noise, even at idle. Higher speeds sounds like the noise is also increasing in repetition. Thanks for any help.
Old Jul 2, 2006 | 11:35 AM
Fobtions's Avatar
Default Re: Transmission noise. Whats the culprit? (crxisok)
throwout bearing
Old Jul 2, 2006 | 01:06 PM
.Manny.'s Avatar
Touching My Member
Default Re: Transmission noise. Whats the culprit? (Fobtions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">throwout bearing</TD></TR></TABLE>
it could be that, but i have the same prob and it is the main input shaft bearing. its hardly ever the throwout bearing with these 16 yr old trannys.
Old Jul 2, 2006 | 02:36 PM
crxisok's Avatar
Default Re: Transmission noise. Whats the culprit? (90_EF_Si)
The throwout bearing was recently replaced. Is it difficult to replace the main input shaft bearing? O also how long can I drive on it? Thanks
Old Jul 2, 2006 | 06:25 PM
CASTUDILLO01's Avatar
replace main shaft bearing
Old Jul 2, 2006 | 07:20 PM
Cory man's Avatar
Default Re: Transmission noise. Whats the culprit? (CASTUDILLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">replace main shaft bearing</TD></TR></TABLE>
This will fix your problem. Its not that hard to do but I recommend having a Honda service manual handy in case something gets misplaced. A very common problem with alot of Honda manual trans.
Old Jul 2, 2006 | 08:06 PM
white90crxhf's Avatar
change the bearings on the differential while you're at it. all 3 bearings were bad. i drove on mine still it started making a terrible noise
if you look at the FAQ you'll see a link on how to change the mainshaft bearing.
Old Nov 30, 2006 | 01:40 AM
Deo's Avatar
Deo
Default Re: (white90crxhf)
My car has been making similar noises. It goes away at idle when I push the clutch in, sounds kind of like the engine is "hoarse" 50% of the time running through 1st and 2nd gear (though never 3-5).
With temperatures falling fast outside, how long would anyone guess I can let this one go? I'm delivery driving right now, lots of abuse on the car.
Old Nov 30, 2006 | 10:34 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (Deo)
I drove with this bearing whining at me for over two years, although I *DO NOT* beat on my car, so it's hard to say how long someone else's will last.
Old Nov 30, 2006 | 01:44 PM
Gearspeed-Performance's Avatar
Default Re: (wiZCo)
Sounds like Input Shaft bearings. How long it will last...who knows...A day..possibly a year or two. I would change it asap. You will need to disassemble the transmission to get to it. As suggested in another post, I would also change the differential bearings as well. Good Luck
HomicidalHatchBack
10
Nov 11, 2006 05:47 PM
crdcz03
Apr 9, 2005 05:01 PM
Jer'rome
Jun 27, 2004 12:24 PM
98GeeYes-Are
Feb 22, 2004 06:09 PM
shortyz
14
Jan 11, 2003 12:52 PM
