ITR springs/shocks combo installation tips
Old Apr 18, 2002 | 04:24 PM
JL 74's Avatar
25 Year Member
Default ITR springs/shocks combo installation tips
I just bought a used set (just 6k miles) and I am still searching for rear LCAs.
I am just planning ahead and looking for installation tips.
The set is still all intact.
1. How difficult is this installation?
2. I have searched here and Google but can't find any detailed installation instructions.
Any help will be
TIA
Old Apr 18, 2002 | 07:48 PM
intekragsr's Avatar
Default Re: ITR springs/shocks combo installation tips (jl74)
The level of diffuculty depends on if you have a spring compressor, a second person to give you a hand and how tight the last mechanic torqued the bolts(personal experience).
If you have done the procedure before, it should be pretty easy. When I installed springs the other day, I had no spring compressor. Basically I just disconnected the lca bolt, stepped on the brake and moved the strut/shock to the side leaving the top of it still bolted to the top of the tower. I then slowly took the top bolt off the center of the strut and let it shoot out into a towel( making sure the brake lines are clear of the projectile. Assemble the shock and spring making sure they are its seated correctly and re-install.
Sorry if that was kind of confusing. This procedure was simplifed. Message me and ill help u out if no one else can make a better suggestions.
[Modified by intekragsr, 4:49 AM 4/19/2002]
Old Apr 18, 2002 | 09:01 PM
ingrate's Avatar
25 Year Member
Default Re: ITR springs/shocks combo installation tips (intekragsr)
you shouldn't need a spring compressor if the ITR shocks/springs are already assembled. installing springs/shocks is pretty straightforward.. 6 bolts/nuts for each front and 5 for each rear. as for the LCAs sorry can't help ya there
Old Apr 18, 2002 | 09:18 PM
JL 74's Avatar
25 Year Member
Default Re: ITR springs/shocks combo installation tips (In7egrity)
what about removing the stock (GSR) shock/springs set up? Will I need special tools other than socket wrenches?
Thanks for the reply. I am just trying to assess what I will be up against?
Like beer and pizza and help me?
Old Apr 18, 2002 | 10:28 PM
Mr. Softee's Avatar
your gonna need a 14mm, a 17mm and whatever size the wheel lugs are. Plus a nice breaker bar... cuz the bolts on the LCAs are a ******* bitch. Good luck, it's really easy.
Old Apr 19, 2002 | 03:26 AM
Asahi's Avatar
Default Re: ITR springs/shocks combo installation tips (94goldjungsr)
here I wrote this . . . Hope this helps
http://www.bseries.net/html/garage/spring.php
Old Apr 19, 2002 | 07:54 AM
JL 74's Avatar
25 Year Member
Default Re: ITR springs/shocks combo installation tips (Asahi)
Thanks, that is awesome
Youngcity
Honda Civic (2001 - 2005)
37
Sep 17, 2007 06:08 AM
ntegraGS-R
Jan 10, 2006 03:48 PM
Ziatic
Apr 4, 2004 02:17 PM
1hotintegra
Nov 5, 2002 09:19 AM
Chip398193
Oct 11, 2001 06:57 PM
