Changed my fuel filter..got a question...
What is the tq spec on the banjo bolt (spelled right?) on top of the fuel filter. My car seams to buck a little lately after I changed it and I think maybe I have that bolt on to tight. Any other suggestions My car is stock except an AEM Intake.
any help would be appreciated....
-Rob
-Rob
Rob:
the torque spec on the bolt on top is 11 ft lb called the service bolt. the banjo bolt that goes right underneath that is torque valued at 25 ft lb. hope this helps
-Rob
-Rob
did it buck at all before the filter change?
muchoa grasias. I just made the adjustment now. When im driving to work tomorow ill see if that adjustment helps stock the bucking...
-Rob
-Rob
-Rob
I don't think having the bolt too tight will cause it to buck. did you retighten the gas cap after you were done, assuming you loosened it before you started the fuel filter change.
-Rob
ramz7887
Oct 27, 2003 04:27 PM
