AC Removal Write up ?
Does anyone have a writeup on this ? Or that could just explain what to remove and what not to, in order to keep heat. I saw that in previous threads it seemed that there was an arguement about leaving the evaporator.
https://honda-tech.com/zero...age=1
take it all. If you want to keep the heater, leave the evaporator and only remove stuff from the engine bay.
remove fan, remove lines, remove condensor, remove compressor, get a shorter belt, install belt...done.
the ac lines that connect at the firewall are a bitch to get to and unbolt.
floriudabrain
Jan 13, 2006 10:56 PM
MugenHonda
Oct 7, 2005 08:16 PM
dingusjt
Nov 13, 2003 02:10 PM
