I think i really messed something up....
Old Jul 2, 2006 | 09:05 AM
91EFstandard's Avatar
Default I think i really messed something up....
Hey guys I really hope somebody can help me figure out what happened, well this is what happened, I got in my integra to start it up, and i dont use my clutch to start it because i have it bypassed so i dont have too, so i turn the key and i had left it in first cuz i was on a hill, then it made a bad sound and stalled. so i take it out of gear and start it with the clutch in and it starts but my exauhst is loud as hell( sounds like a gokart or something). so i pop open my hood and my engine is rocking while its idleing. anyone have any ideas as to what just happened. im afraid to try and drive it.
Old Jul 2, 2006 | 09:22 AM
cm zak's Avatar
If your engine is moving while idle, probably a mount issue.
Old Jul 2, 2006 | 10:53 AM
qfast817's Avatar
Default Re: (cm zak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">If your engine is moving while idle, probably a mount issue.</TD></TR></TABLE>
look at the rear mount
Old Jul 2, 2006 | 10:58 AM
ProjectDarkBlack's Avatar
Default Re: (qfast817)
that has happened to me like 5 times ha ha. You probably tore a mount and gained an exhaust leak
AARON26's Avatar
YEAH, DEF. A MOTOR MOUNT BRO..G/L
Old Jul 2, 2006 | 11:39 AM
Sic_DA_Nine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">
look at the rear mount</TD></TR></TABLE>
i hate messing with that mount...
its a bitch to get to
if it is the rear mount.....have fun
Old Jul 2, 2006 | 12:20 PM
Default Re: (Sic_DC_FOE)
well if it is the mounts im in luck because i got a set of innovative mounts a couple of weeks ago, and a buddy of mine is doing the install for free. i hope thats all i messed up. what would have exactly caused the exhaust leak(if there is one) and if i take it to a muffler shop is it an easy fix?
Old Jul 2, 2006 | 02:44 PM
Default Re: (91EFstandard)
damn, i just started it up again and im hearing a knock. could a rod knock be caused by something like this?
Old Jul 2, 2006 | 03:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sic_DC_FOE &raquo;</TD></TR><TR><TD CLASS="quote">
if it is the rear mount.....have fun </TD></TR></TABLE>
The worst memory I have about working on my car
Old Jul 2, 2006 | 04:35 PM
Diego Dangers.'s Avatar
Default Re: (ProjectDarkBlack)
its a pretty shitty mount. I took off the intake manifold bracket and did it in a few minutes.
Old Jul 2, 2006 | 04:51 PM
Uncle Willie's Avatar
Default Re: (Diego Dangers.)
When the motor mount broke, that caused the motor to move excessively and pretty much "pulled" the exhaust apart...or broke a weld or two.
Old Jul 2, 2006 | 07:19 PM
Default Re: (RIP Indian Larry)
alright its fixed, wasnt a broken mount and theres no exhaust leak. somehow either when i left it in gear and tried to start it or when i was plugging in my ecu, one of the wires came undone. Causing my exhaust to sound like **** and my idle to drop really low, then causing the motor to rock because of such a low idle. Put the wire back in and everything was idling perfect and exhaust sounds great, then no vtec, pull the ecu again to find another wire pulled out. My brother pulled some McGyver **** with the stuff i had in my car, and got all the wires back in, and now its runnin like a champ. Im just so relieved now, thanks for the help guys.
Jackandcoke
Honda CR-V & Element
Apr 21, 2018 01:30 PM
James Burriss
Feb 16, 2015 07:39 AM
xanatos
Honda Civic (2006 - 2015)
16
Aug 10, 2008 06:48 AM
ef0cmacro
Aug 23, 2006 08:13 PM
OSIRIuS23
Dec 25, 2005 08:59 PM
