6mm Brake Disk Retaining Screw problems....
Old Jul 2, 2006 | 08:55 AM
GSRNetics's Avatar
Default 6mm Brake Disk Retaining Screw problems....
Okay, yesterday I decided it would be a good day to do my caliper and brake rotor replacement. Got the wheel off for the first rotor/caliper change, and attempted to remove the 6mm screws that hold the rotors in. When I went to Honda to buy 4 new screws, the guy told me 20 to 1 the screws are going to strip out, and that I will either have to A) Drill out the heads of the screws, then pull the rotor off and take a vice grip to the remaining part of the screw, or B) Take a chisel like screwdriver, and drive the sharp end in the head of the screw and try turning out. I don't have any of those above mentioned tools, and tried using a #2 Phillips head screw driver. Well I had no luck as the screw head started stripping out. I immediately stopped and gave up seeing as how probably ALL the screws are going to be like this.
EDIT: I've never drilled out a screw head before or anything like that for that matter.
So does anybody know any good drill/bit combos, or even what the chisel drive type of screwdriver is called? My passenger caliper is starting to mess up and squeak non-stop when I'm driving, but goes away when I PRESS the brakes.
Old Jul 2, 2006 | 09:47 AM
Dartanian's Avatar
Default Re: 6mm Brake Disk Retaining Screw problems.... (93DALS)
Just get a drill bit that is slightly smaller than the head of the screw and start drilling away. It will shred out the head leaving the base and the rotor will come loose.
When you put the new rotors on, don't put the screws back in. The wheel pressed against the rotor is more than sufficient in keeping it in place.
Old Jul 2, 2006 | 10:06 AM
nsxtasy's Avatar
H-T Order of Merit
You need to get a tool called an impact driver, which you can get at Sears or any good auto parts store. It looks like a screwdriver, but it's designed to be hit with a hammer/mallet which makes it turn ever so slightly. This is the "chisel type screwdriver" he was referring to.
Click on photo below for more info.
$6.99 at Harbor Freight:
$24.99 at Sears:
Old Jul 2, 2006 | 10:10 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 6mm Brake Disk Retaining Screw problems.... (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You need to get a tool called an impact driver, which you can get at Sears or any good auto parts store. It looks like a screwdriver, but it's designed to be hit with a hammer/mallet which makes it turn ever so slightly.
This is an impact driver:
http://www.sears.com/sr/javasr...e=Yes
Right now, if the philips screw is not messed up too bad, the impact driver should still work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DALS &raquo;</TD></TR><TR><TD CLASS="quote">...what the chisel drive type of screwdriver is called? </TD></TR></TABLE>
I think the guy is referring to a cold chisel.
You can just buy one chisel from any hardware parts store.
Here is a post regarding using the cold chisel:
https://honda-tech.com/zerothread/1676031
Old Jul 2, 2006 | 10:17 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: 6mm Brake Disk Retaining Screw problems.... (tech8)
Try the impact driver first. If it's not totally stripped, that should work. If it's fully stripped, then you can try one of the other measures.
Old Jul 2, 2006 | 10:27 AM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
i ran into this with my DA. it took a while with our drill, but we eventually got all of the screws out.
Old Jul 2, 2006 | 11:43 AM
Sic_DA_Nine's Avatar
you coulda used the phillips and hammered the **** outta it from the rear....
the screws woulda came loose
Old Jul 2, 2006 | 11:46 AM
Haleiwa-Brando's Avatar
Default Re: (Sic_DC_FOE)
Remember, Honda and Acura wheels are hub-centric. So when you put the rotor back on...followed by the wheel, it will center it's self and you don't have to use those stupid screws.
Every track guy I know, don't use those screws.
Old Jul 2, 2006 | 12:38 PM
00IntegrAllmotoR's Avatar
HT Black OPs
Default Re: (Haleiwa-Brando)
Look up made topics I've done, I did a nice DIY on how to get those babies off. Use the impact driver first and if that doesn't work the BEST to use is a torch for just 1 min.
Old Jul 2, 2006 | 02:19 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (00IntegrAllmotoR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">Look up made topics I've done, I did a nice DIY on how to get those babies off. Use the impact driver first and if that doesn't work the BEST to use is a torch for just 1 min.</TD></TR></TABLE>
The topic is here.
Modified by nsxtasy at 11:01 AM 7/3/2006
Old Jul 2, 2006 | 02:35 PM
GSRNetics's Avatar
Default Re: (nsxtasy)
Awsome, I truely appreciate everyones help and contributions. When I went to Honda for the screws, they gave me their last 3, so I guess I should just ditch em eh?
Old Jul 2, 2006 | 02:50 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (93DALS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93DALS &raquo;</TD></TR><TR><TD CLASS="quote">Awsome, I truely appreciate everyones help and contributions. When I went to Honda for the screws, they gave me their last 3, so I guess I should just ditch em eh?</TD></TR></TABLE>
That's up to you; there's no consensus. I use mine. I find it easier to leave the rotors securely attached when changing brake pads and such...
Old Jul 2, 2006 | 02:53 PM
Flexin5's Avatar
i just drill out the face of the screw, then hit the old rotor hard with a hammer, it pops right off and takes 2mins.
Old Jul 2, 2006 | 03:00 PM
96 GSR-T's Avatar
Default Re: (Flexin5)
If you dont have an impact hammer, a not as effective substitute (works for me every time) is just stick the phillips head screwdriver on the screw and wack the back of it with a hammer, same basic principle just not as strong.
Old Jul 2, 2006 | 04:56 PM
Uncle Willie's Avatar
Default Re: (96 GSR-T)
I used a grinder and cut a slot in the screw head (it went into the rotor also). Then i took the biggest flathead screwdriver i had and forced it in the slot. Then i used a vice grip on the screwdriver shaft and turned that baby out of their. This came all after the impact screwdriver had failed.
Old Jul 2, 2006 | 04:59 PM
HT Black OPs
Default Re: (RIP Indian Larry)
The pics on my thread are back,
https://honda-tech.com/zerothread?id=1439058
CR-V Buckeye
Suspension & Brakes
Sep 3, 2018 03:15 AM
Integra4lyfe069
Apr 11, 2009 06:43 AM
a1320addict
Jan 17, 2006 10:16 PM
Sportsguy
Feb 27, 2005 05:18 PM
spnbb2
Nov 28, 2004 01:03 PM
