1991 Civic EX with Code Issues Running JDM b18c on OBD 1 P28 Hondata
Old Jul 2, 2006 | 08:24 AM
ruby civic II's Avatar
Default 1991 Civic EX with Code Issues Running JDM b18c on OBD 1 P28 Hondata
OK, what would be the problem: I run a steady blinking light once I push the red button on the Hondata to give codes. The car runs rich and goes into limp home mode with poor idle control but holds RPM at same throttle position.
The plugs look OK, dizzy OK checked. Fuel pressure 40 psi w/ vacuum hose attached. Car does run Toda B cams.
Any ideas?
Old Jul 2, 2006 | 02:19 PM
Default Re: 1991 Civic EX with Code Issues Running JDM b18c on OBD 1 P28 Hondata (ruby civic II)
OK, I know there are some truly nerdy nerds out there, so any help???
Thanks, all.
Old Jul 5, 2006 | 01:53 PM
OK, any ideas? Could this be just what happens on base Hondata settings??
Thateguhate
Apr 27, 2007 03:01 PM
itgsr98
Jul 2, 2005 08:56 AM
autoEXturbo
Apr 25, 2003 09:41 AM
BoostedGSRBubble
Mar 4, 2003 01:20 PM
BlackGSR
Aug 12, 2002 09:34 PM
