weird car wont start problem
i have slimed it down to 2 probelms either my alternator or my battery....the car starts when jumped or on a rolling start, once turned off lights still come on but when tryin to crank nothing, so i got lights inside car but when tryin to crank i get nothing, feels like theres not enough juice. any one ever have this problem thanks
bump
i think im having the same problem. my car drove fine the night before at like 11:30pm, then when i go to start it at about 10:00am it wont fire. it seems to me the "isn't enough juice" either =\
Sounds like a battery problem... Does the car run fine for a lond period of time once you get it started? If so you need a battery...
could b main relay. i have same prob. does it start after couple of mins? turn ignition on and off couple of times and it should engage. its a fault on soldering. bout 80 quid to replace.
i had the same weird problem, and the ground wire on the tranny was loose. i didnt think that it would have made a difference, but sure enough i tightened it and problem fixed.
I have the answer !!!!!
I tried to get help on the same damn problem for over a year for my son's '95 Civic. We tried all of the numerous fixes such a ground straps, starter, battery. Even considered replacing the ignition control module, but since we could roll start the car I figured it was not the module. Then it hit mer. What is the one component between your ignition switch and the starter? The starter interrupt swith at the top of the clutch lever !!!!!!!
I pulled the plug off of the switch, stuck in a paper clip and the car fired right up !!!!
You can try adjusting the switch to get it closer to the lever, you could add something to the lever to make up the difference, or you can bypass it altogether with a short wire connecting the sockets in the plug. We taped the paper clip in place... I know that is a little ghetto, but it is REALLY hard to get your hands up in there. (I know, that's what she said...)
I hope this helps all of you with the weird "won't start" problems.
c|rop3asy==[]
Sep 7, 2013 08:59 PM
