Aiming new headlights
Old Jul 1, 2006 | 07:59 PM
sony224422's Avatar
Default Aiming new headlights
I took out my stock headlights and put in H1 bulb angel eyes. How do i go about aiming them.. they are deffiantly off. I know on the stock ones there was a screw you'd turn, but there isn't a spring or anything like that on the bottom of them to adjust them. There are bolts that i guess you could twist that are right near the lights themselfs, so is that what i'd use?
Btw, these are def alot brighter than the stock headlights to anyone who was wondering.
Old Jul 1, 2006 | 10:05 PM
H(alo)oNdA 5thG's Avatar
Default Re: Aiming new headlights (sony224422)
There's a screw ontop of the housing that should let u either tighten or loosen with a philips screw driver to raise and lower the housing some and if that doesn't get it then there are bolts that can be adjusted but ur looking at taking off the front bumper you should be able to aim ur lights one of the two wayz. I personally use a garage door or a building of some sort so see where my cut-off lines are. . . Also be sure to check the fitting of the bulb in the back of the housing. . sometimes u just have to make sure u have the bulbs put in correctly. . level and flush.
DaMenaCe
Jan 31, 2009 02:16 PM
lxaccord51oxl
Jun 23, 2006 02:34 PM
Kyles ej1
16
May 20, 2005 12:50 AM
jerknob
Mar 20, 2003 10:54 AM
weakGOODJunKieS.com
Oct 17, 2002 03:18 AM
