ls crank and rods into gsr block
Old Jul 1, 2006 | 04:42 PM
jdmteg93's Avatar
Default ls crank and rods into gsr block
what all has to be done to put ls crank and rods into a gsr block . spun bearing and want find a quick fix will this fit ???
thanks
jon
Old Jul 1, 2006 | 05:55 PM
jdmteg93's Avatar
Default Re: ls crank and rods into gsr block (jdmteg93)
anybody?
Old Jul 2, 2006 | 12:15 PM
jdmteg93's Avatar
Old Jul 2, 2006 | 12:20 PM
Syndacate's Avatar
Blah, they should work fine..but I don't wanna tell you that and then u go install 'em and they don't.....so wait for somebody that knows 'em better :-\
Old Jul 2, 2006 | 12:46 PM
SkoundrelUSA's Avatar
cute little bastard
From what I have read, they work but you need to plug or block the oil squarters. I know GE sells the plugs. Other than that I don't know.
Old Jul 2, 2006 | 01:04 PM
gold_ef's Avatar
B18C stroke=87.20 MM
B18A/B stroke=89.00 MM
B18C rod length=137.90 MM
B18A/B rod length=137.00 MM
so your pistons will hit the head if you try it, and thats worse then having to find a new B18c crank and rods
Old Jul 3, 2006 | 02:12 PM
jdmteg93's Avatar
Default Re: (gold_ef)
thanks for the info
jon
Old Jul 5, 2006 | 01:38 PM
gold_ef's Avatar
sorry, i gave wrong information...all b18's have the same deck height so this WILL work
Old Jul 5, 2006 | 03:25 PM
dohcMONSTER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gold_ef &raquo;</TD></TR><TR><TD CLASS="quote">sorry, i gave wrong information...all b18's have the same deck height so this WILL work</TD></TR></TABLE>
yes it will work. you have to use LS rods and an LS crank. you will have to either bend or remove the oil squirters that are on the block. Unless this is the only crank you have present i wouldnt reccomend to extra 1.28mm stroke for a less reliable (for higher revving) and weaker crank
jdmH2Bek4
Dec 22, 2012 01:14 PM
beyondstock
Mar 8, 2009 12:41 AM
integranator
May 12, 2006 02:56 AM
Kelly.
42
Oct 18, 2005 11:14 PM
JeremyL
Dec 6, 2002 01:45 PM
