A/C Problem
Old Jul 1, 2006 | 12:54 PM
Gsr94black's Avatar
Default A/C Problem
I just bought a daily driver, '90 LS teg. I was sitting in it the other day and decided to run the a/c since it was hot. Well as i sit there and it runs it blows nice and cold...i then went to drive off and as soon as the rpm's hit 2-3,000 the belt started sqeeking like crazy but then stopped after about 5 sec. At this point the a/c starts to play games. Some times it will continue to blow cold and other times it won't. As soon as i stop though the a/c blows cold everytime or if i throw it in nuetral while going it will blow cold. What do you guys think it is? You think it could be the belt is old and i need a new one and that is causing it to slip after it hits 2-3,000 rpm's? Any help would be greatly appreciated. Thanks
Old Jul 1, 2006 | 01:29 PM
TSX TEX's Avatar
Default Re: A/C Problem (Gsr94black)
I would start by replacing the belt. If that doesn't do the trick then trouble shoot from there.
amej8
Jun 1, 2007 09:00 PM
Draggin99Si
Jan 20, 2006 04:48 AM
hondacrxflyer
Dec 3, 2004 07:29 AM
jonoknut
Feb 15, 2003 11:21 PM
tinkfist
Jan 28, 2003 04:11 PM
