SKUNK2 parts for turbo set up
Old Jul 1, 2006 | 11:39 AM
egVTI's Avatar
Default SKUNK2 parts for turbo set up
he my tuner said my n/a toda cams are causing my mega flat spot in the mid range. this in on a b16 , he said n/a cams have high lift and long duration n o a boosted set up you want high lift but a short durtation
so was looking a doing the head completely wot you thinks of this -
skunk2 turbo cams stage 2
skunk2 pro series intake
skunk2 70mm T/B
skunk2 valvesprings
skunk2 retainers
anyone used the turbo cams from skunk2? stage 1 or 2?
any other reccomendations ?
thanks for any help you guys give
Old Jul 1, 2006 | 12:08 PM
grtek's Avatar
Default Re: SKUNK2 parts for turbo set up (egVTI)
I didn't even know skunk2 made stage2 turbo cams
Old Jul 1, 2006 | 12:13 PM
egVTI's Avatar
Default Re: SKUNK2 parts for turbo set up (grtek)
yeah i think there pretty new tho
Old Jul 1, 2006 | 12:15 PM
DaveF's Avatar
post up your dyno chart. your flat spot is probably because your "tuner" is turning your vtec on tooo late.....
stock gsr/itr cams would most likely be better for your setup.
skunk turbocams are
Old Jul 1, 2006 | 01:52 PM
egVTI's Avatar
Default Re: SKUNK2 parts for turbo set up (dturbocivic)
aint got a scanner here the now but the graph kinda goes like this
3k -105lbs
3.5k -112lbs
4k -128lbs
4.5k -130lbs
5k -139lbs
5.5k -137lbs
6k -126lbs
6.5k -129lbs
7k -141lbs
7.5k -152lbs
8k -155lbs
8.5k -162lbs
all the torque fig thru rev range
its b16 stock internals ,drag gen 3 kit @7psi with toda cams
so you think dont use the skunk2 turbo ones?
Old Jul 1, 2006 | 02:31 PM
DaveF's Avatar
you wont get the most of those cams unless you are really on a huge, free flowing turbo setup. your setup has too much backpressure for them cams.
Old Jul 1, 2006 | 03:54 PM
egVTI's Avatar
wot can be dont to get the best resuls from those turbo cams?
Old Jul 1, 2006 | 04:25 PM
DaveF's Avatar
with the cams you have now? or the other cams you are tryin to get?
Old Jul 1, 2006 | 04:35 PM
egVTI's Avatar
should i take the toda's out for something with less duration? like skunk2 turbo ones? blox turbo ones?
Old Jul 1, 2006 | 07:09 PM
boosted94cx's Avatar
* B A N N E D *
why not something simple like ITR/CTR cams?
EGCoupeVtec
Feb 11, 2009 06:00 AM
patrick4588
Jul 16, 2008 11:27 AM
asianic415
Dec 7, 2003 08:46 AM
nerces
Jan 13, 2003 05:33 PM
