Homework for a b18c swap in a 92 DA
Old Jul 1, 2006 | 10:15 AM
killin me smalls's Avatar
Default Homework for a b18c swap in a 92 DA
Ok i've been looking around here to get alot of information for my swap. Most likely what im going to be purchasing is the b18c complete changover from hmotorsonline.
Right now my car is AUTO. So im a little confused what to do with the hyro tranny. Do I first buy a cable pedal setup and buy the cable-to-hydro kit?
Old Jul 1, 2006 | 10:25 AM
aziz93's Avatar
Default Re: Homework for a b18c swap in a 92 DA (killin me smalls)
a 5 speed into a 92 auto? have fun!
seeing that its a 92 automatic and you want to put in a five speed. i would just sell the car and buy another 92 5 speed for cheap as most are and then put in your motor of choice.
Old Jul 1, 2006 | 10:39 AM
JDMorgan's Avatar
i got a 5sp conversion for sale. you can run hydro clutch pedal, master cyl, and slave cylinder if you want a better clutch feel than the innovative kit.
Old Jul 1, 2006 | 11:54 AM
Default Re: (KraZEtEggIE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">i got a 5sp conversion for sale. you can run hydro clutch pedal, master cyl, and slave cylinder if you want a better clutch feel than the innovative kit.</TD></TR></TABLE>
Ok I think I will go that route, I havnt searched this yet but what hydro pedal assembly will bolt in?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aziz93 &raquo;</TD></TR><TR><TD CLASS="quote">a 5 speed into a 92 auto? have fun!
seeing that its a 92 automatic and you want to put in a five speed. i would just sell the car and buy another 92 5 speed for cheap as most are and then put in your motor of choice.</TD></TR></TABLE>
I Got the car for a killer deal so by the time I sell it and buy another it wont be worth it.
Old Jul 1, 2006 | 01:22 PM
JDMorgan's Avatar
http://www.g2ic.com/forums/sho...hydro
Old Jul 1, 2006 | 01:44 PM
projectTeG's Avatar
just get the 5-speed cable to hydro kit, then shim the mount its self up a inch with som in thick grade 8 nuts the other 2 mounts will bolt up just fine. ive done a 5-speed swap on a 93 DA and i did the shim trick with the stock mounts.
Old Jul 1, 2006 | 02:23 PM
Default Re: (projectTeG)
Thanks everyone, my questions were answered
One more thing will the 94-up shiftlinkage be ok?
Old Jul 1, 2006 | 02:31 PM
JDMorgan's Avatar
hydro uses a differant mount. u can only shim auto to cable 5sp conversion.
Old Jul 1, 2006 | 03:55 PM
mike9571's Avatar
Default Re: (killin me smalls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killin me smalls &raquo;</TD></TR><TR><TD CLASS="quote">
One more thing will the 94-up shiftlinkage be ok?</TD></TR></TABLE>
Yes
Old Jul 2, 2006 | 01:17 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE &raquo;</TD></TR><TR><TD CLASS="quote">hydro uses a differant mount. u can only shim auto to cable 5sp conversion.</TD></TR></TABLE>
i am aware of that, but the only difference between the auto and manual trannies in the da is the hieght of the mount from the tranny to the chassis(which is one inch) so all you really have to do is shim the hydro conversion moun up one inch.
the chassis mount brackets are different so that is why you have to shim the mount up
Old Jul 2, 2006 | 03:26 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">i am aware of that, but the only difference between the auto and manual trannies in the da is the hieght of the mount from the tranny to the chassis(which is one inch) so all you really have to do is shim the hydro conversion moun up one inch.
the chassis mount brackets are different so that is why you have to shim the mount up</TD></TR></TABLE>
How safe is that?
Old Jul 2, 2006 | 03:53 PM
projectTeG's Avatar
Default Re: (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">How safe is that?</TD></TR></TABLE>
if you increase the size of the bolts and get grade 8 nuts and bolts then you will be fine. i went about a year with no problems be fore i swapped my set-up into into a manual DA chassis
glhsdrew
May 15, 2015 05:44 PM
B.D
Jan 3, 2005 06:16 AM
accord85
Jul 15, 2004 10:34 PM
bartek_b
Acura TL, RL & ZDX
Oct 18, 2003 01:40 AM
B17swappedEG
May 11, 2003 05:53 PM
