Installing Compustar/Viper Alarm w/no power locks,windows?
Official H-T Cake Maker
Alright. Can i install a CompuSTAR or Viper Alarm. Both Paging ones.. in a car without power windows or locks? this is going in a civic ek hatchback.
Do i have to install power windows and locks? or can i install it as it comes?
Thanks
Thanks
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
You just won't have keyless entry when you disarm the car. It will work, But later you could add power locks if you want to.
run the power lock wires to the door areas... so you don't have to pull ur car apart again...
make sure u insulate the ends...and hide the wires... cause they would just lead straight to ur alarm brain if a theif finds them...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bpr0422 »</TD></TR><TR><TD CLASS="quote">run the power lock wires to the door areas... so you don't have to pull ur car apart again...
make sure u insulate the ends...and hide the wires... cause they would just lead straight to ur alarm brain if a theif finds them...</TD></TR></TABLE>A Compustar alarm does not have door lock relays built in, so he would have to install a pr. of relays also, so if he was to run the power door lock wires he should run them to where the relays would be mounted. and as they are neg. (-), [low current] out puts insulating the ends is not necessary, although hiding all alarm wiring is.
94
94
B-Rabbit20
Aug 18, 2015 01:08 PM
tctruong94
18
Jan 31, 2012 01:23 AM
