cometic head gasket, stock head gasket thicknes...
Old Apr 18, 2002 | 01:38 PM
schwett's Avatar
New User
Default cometic head gasket, stock head gasket thicknes...
anyone know the thickness of a stock h22a4 head gasket? i need a new one, can't decide if i should go stock or cometic. if i go with a VERY slightly thinner one to offset a slightly-lower-than-desired CR (due to piston choices), will i need to adjust anything else?
thanks in advance.......................
and btw, wtf is the h22 gasket SO MUCH more expensive than others? it's like $150+!!
Old Apr 18, 2002 | 01:43 PM
dustin's Avatar
Default Re: cometic head gasket, stock head gasket thicknes... (schwett)
oem honda head gasket for h22a4 is $46.12 @ hondaautomotiveparts.com
Old Apr 18, 2002 | 01:50 PM
schwett's Avatar
New User
Default Re: cometic head gasket, stock head gasket thicknes... (dustin)
indeed it is; i was referring to the cometic one, which i saw for $185.95 at race engineering... but then i noticed that's for a .098" 88mm gasket. the 87mm, .030" cometic gasket is only $65.
so, what's the thickness of the stock head gasket? i can't really tell how it would be measured from looking at mine.
Old Apr 18, 2002 | 01:55 PM
dustin's Avatar
just use a stock headgasket. I'm sure you can find decent compression pistons.
Old Apr 18, 2002 | 02:08 PM
turbo Si's Avatar
A stock Honda head gasket is .32 thousands of an inch. Atleast that is what it is for B series motors. I am sure it will be the same though. Why don't you go direct to Cometic. You should talk with them first because my brothers head gasket is still on backorder with those guys. I can't complain though for the price they charge.
Good luck!
Old Apr 18, 2002 | 04:19 PM
schwett's Avatar
New User
Default Re: cometic head gasket, stock head gasket thicknes... (dsmturbosi)
thank you.
Good luck!
riceball777
May 17, 2004 07:10 PM
ejectseat
May 9, 2003 05:38 AM
SRT-WHORE
Sep 2, 2002 10:15 PM
BoostinDC2
Feb 19, 2002 09:08 PM
therealnapster
Sep 9, 2001 08:07 PM
