getting turn signals to work after integra dash swap.
Old Jun 30, 2006 | 04:33 PM
streetracerof06's Avatar
Default getting turn signals to work after integra dash swap.
I just put an integra dash swap into my 92 hatch, and the only thing not working is the turn signals, I know there is a write up that says what wires to put together when using the integra dash harness, but i used the civic harness. I also know that the green with yellow stripe wire is the right turn signal and the green with blue stripe is the left. I tried splicing the right signal wire into a couple of different power wires but the signal just stayed on and did not blink. Does anyone know which wire I should splice my turn signals into to make them work. Thanks.
Old Jul 1, 2006 | 10:12 AM
Default Re: getting turn signals to work after integra dash swap. (streetracerof06)
bump
Old Jul 1, 2006 | 02:21 PM
somebody please help me
Old Jul 1, 2006 | 04:12 PM
Battle2.0Eg's Avatar
just get the diagram for the integra cluster wiring and find the color of the turn signals. Then do the same to the civic harness and wire them up. I did that and as long as your hazard switch is hooked up it should work.
Old Jul 1, 2006 | 04:14 PM
Default Re: getting turn signals to work after integra dash swap. (Battle2.0Eg)
here u go this should help you.
hey DB8 hope this helps
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
Old Jul 1, 2006 | 10:22 PM
I have those wires hooked up but I did not hook my hazards up, I guess I will try that tomorrow, thanks.
Old Jul 2, 2006 | 02:58 AM
Yes if your hazard switch is not hooked up properly or not hooked up at all ur blinkers will not work.
Old Jul 2, 2006 | 10:06 AM
thank you so much, I plugged in the hazard switch and my blinkers work, thanks a lot man.
Old Jul 3, 2006 | 11:20 AM
No problem.
Old Jul 3, 2006 | 11:22 AM
standinghollow's Avatar
streetracerof06
Jul 3, 2006 02:21 PM
streetracerof06
Jun 28, 2006 03:33 PM
mattharper
Aug 5, 2005 11:08 AM
rtiadnoh
May 6, 2004 12:34 PM
