Wondering if a chip in a fried ECU is bad if the ecu wen't bad because of a short...
Old Jun 30, 2006 | 12:11 PM
Naudlee's Avatar
Default Wondering if a chip in a fried ECU is bad if the ecu wen't bad because of a short...
basically the title says it all, whats your opinion? No visible damage near the chip or anything...? anyone?
Old Jun 30, 2006 | 12:15 PM
Relic1's Avatar
cut J1 in the ECU. if everything works fine it's the chip.
BTW, you need to at least give us some idea of what you are talking about. what setup, what ECU, what chip, what program in the chip, what symptoms.
Old Jun 30, 2006 | 12:20 PM
Naudlee's Avatar
Alright I had anightmare electrical problem pinpointing spree, my alternator plug grounded out on a metal tube and caused a short int he system blowing the 80amp battery fuse and frying the ecu... THe chip was a blank chip correctly tuned on a dyno... In an obd1 ecu... I put the stock obd2 ecu back in and the car started up, so it had to be the ecu's fried, or is it the chip, which I doubt? I'm looking for another obd1 ecu as of now.... any of this help, excuse my typing
99 DX hatch
99 ITR b18c5 motor swapped in
Old Jun 30, 2006 | 12:34 PM
Relic1's Avatar
the alternator control lines are not chip related. Sounds like you popped the ECU.
it might be repairable though, hit me up. I have a few OBD1 ECUs for parts.
Old Jun 30, 2006 | 02:33 PM
Naudlee's Avatar
alright because witht he obd2 ecu in it, I'm noticing its not as responsive, pep-wise, you know... what do you have for obd1 ecu's (working)
DesertCivic
Nov 19, 2004 01:37 PM
5STAR3
Mar 20, 2004 04:40 PM
