heatshield rattle? driving me crazy!
Old Apr 18, 2002 | 12:44 PM
.MilanoRex's Avatar
Default heatshield rattle? driving me crazy!
my crx is lowered and theres a rattle in the back when i'm around 2500-3k. Some people have said its the heatshield, where exactly is that? and how can i fix it?
Old Apr 18, 2002 | 01:06 PM
Toxic's Avatar
Default Re: heatshield rattle? driving me crazy! (crXtreme)
its a metal shield between the bottom of your car and the exhaust pipe, basicall runs down the middle of your car, has about ten 10mm bolts holding it in, take it out.
Old Apr 18, 2002 | 01:20 PM
.MilanoRex's Avatar
Default Re: heatshield rattle? driving me crazy! (Toxic)
for now, i park right ontop of grass(most of it is dried up) so removing the heatshield wouldnt be good.
Old Apr 18, 2002 | 01:47 PM
HumanResource's Avatar
Park on Grass???
I'm assuming you did your swap barefooted and with out a shirt as well???
Could be a number of things like the cat or something in the exhaust. Best to have a muffler shop check it out.
Old Apr 18, 2002 | 01:53 PM
.MilanoRex's Avatar
Default Re: heatshield rattle? driving me crazy! (Chris90STD)
lol no... i have too many cars at my house and my little rex gets to sleep next to the driveway.
Old Apr 18, 2002 | 01:57 PM
Trinity's Avatar
just take the damn thing off, voala, no more problem. it also might be the honey comb in your cat if you have one
Old Apr 18, 2002 | 04:18 PM
MR CRX's Avatar
Default Re: heatshield rattle? driving me crazy! (Trinity)
i had the same tinny rattle noise on my rex a few months back
then i just took the heat shield off the exhaust and no noise wotsoever..its just a thin metal plate on top of ure exhaust pipe..does pretty much shitall...
hope thats the actual problem and nothing else though
cheers
Old Apr 18, 2002 | 04:23 PM
fixhondas's Avatar
Sometimes if you wrap a CV boot clamp or hose clamp around it will help for a short while.
Old Apr 18, 2002 | 10:02 PM
martini's Avatar
No, crxtreme, the heat shield is between your floor board, and the exhaust piping/muffler. So without it, you would be no more inclined to start your lawn on fire than with it on..
Personally, I would try to find where it rattling back there first, and see if you can just bend the heatshield back or something like that, instead of removing it altogether. Maybe it's not a big deal on CRXs, but if you remove that **** on a modified rotary car, you're likely to melt your carpeting.
Old Apr 19, 2002 | 12:41 PM
fixhondas's Avatar
Default Re: heatshield rattle? driving me crazy! (martini)
I was referring to the heatshield on the bottom of the converter. I haven't seen a fire start from a converter yet- but if you were running way rich and it got red hot I would worry. Take off and clamp what you can-
lalocivic
Aug 13, 2009 10:04 PM
bonstokLS
Jan 4, 2009 06:48 PM
jayare05
11
Nov 23, 2004 08:18 PM
mdpalmer
Oct 4, 2004 12:19 PM
geminis2k
Oct 26, 2003 04:30 PM
