disk brake swap
Old Jun 30, 2006 | 11:04 AM
bl_harden's Avatar
Default disk brake swap
Ive gotta 91 crx hf stocker, and i wann upgrade the brakes. I have already purchased the rears from 93 teg as well as the brake booster and master cylinder. Oh, I got the 4040 prop valve too. As for the front swap, can I use the integra spindles or should I go with the Si equipment? Do I need the Si e-brake cables and rear brake lines as well? Any info would be greatly appreciated. Please tell my I bought the right components.
Old Jun 30, 2006 | 11:11 AM
BlackLudeSi's Avatar
Default Re: disk brake swap (bl_harden)
As far as brakes lines and cables go, yea get them all from the teg, as far as the front goes, I think the HF's have smaller axels, someone correct me if im wrong.
Old Jun 30, 2006 | 01:39 PM
91rexman's Avatar
Default Re: disk brake swap (BlackLudeSi)
yes the hf has the smaller driveaxles
Old Jul 3, 2006 | 02:01 PM
jamesknightsi's Avatar
Default Re: disk brake swap (91rexman)
Best way to do a Front brake conversion is to do it what u do an engine swap..
For ex.. If u do a USDM B16 get the Si front brake assembly.. makes it alot easier.
Old Jul 3, 2006 | 02:48 PM
JokerTypeR's Avatar
Default Re: disk brake swap (jamesknightsi)
For the rear discs, the teg offers all that you need. Hit up autozone, and order the brake lines for a 88-91 crx Si W/ REAR DISCS. You can use the ebrake cables from it. Everything else is direct plug and play on the rear. Can't help you on the front side.
Old Jul 3, 2006 | 02:58 PM
mahatma's Avatar
Default Re: disk brake swap (JokerTypeR)
get the whole front spindles w/brakes from the teg. after that all you need are dx/si axles
i have a set you can have on the CHEAP too (local)
Old Jul 3, 2006 | 03:05 PM
JokerTypeR's Avatar
Default Re: disk brake swap (mahatma)
Yeah, but it throws off the camber a bit...at least I thought i heard someone say that...where as the EX is direct bolt on. Something along those lines...? Correct me if wrong?
Old Jul 3, 2006 | 03:15 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JokerTypeR &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, but it throws off the camber a bit...at least I thought i heard someone say that...where as the EX is direct bolt on. Something along those lines...? Correct me if wrong?</TD></TR></TABLE>
I used the DA knuckles and all I did was get an alignment after it was done and my 88 crx runs like a champ and stops on a dime.
Old Jul 3, 2006 | 03:19 PM
JokerTypeR's Avatar
Default Re: disk brake swap (EL Vap133)
...anyone got these things for sale?
haha, just kidding. I'm broke right now.
However, they're MUCH easier to find than EX knuckles. I'll consider my swap next summer when I can hav ea job again.
Old Jul 5, 2006 | 10:27 AM
I have the Front spindals off a 90-93 integra. in good condition...
they have the brake lines still intact.. i have the integ. rear conversion to but thats not for sale...
Send me an email if u are interested in the front spidals. if u are interested...
james
Old Jul 5, 2006 | 02:04 PM
bl_harden's Avatar
I would be interested in nay parts you might have. lemme know what you've got and how much you want for everything
Old Jul 5, 2006 | 02:07 PM
Jonathan_ED3's Avatar
I would recommend only buying the calipers and knuckles from a junkyard.
Buy your rotors brand new. Most of the rotors I find at the junkyard are worn beyond serviceable limits. Maybe you guys have a little more luck around your parts.
GeoMetry
Nov 11, 2015 09:20 AM
gRim06
Oct 28, 2007 02:14 PM
coot_er
17
Jan 27, 2007 11:22 AM
WVTURBOCRX
Nov 27, 2005 06:29 PM
sabertooth
Jan 7, 2004 10:09 PM
