obd1 - obd2 harness
Could someone please post the skematics to make an obd1 -2 harness. I want to get a hondata and I can get the jumpers for free. I am sure there is lots op people that could really benifit from that info.
Thanks,
Thanks,
I did do a search. You're right there was a post about this but nobody disclosed because they are all trying to make a buck and don't want to help anybody!!!!!!
I even said please.
I know you guys have probably heard this song and dance before, But I live in Canada. So I am used to a shitty unfair dollar value, I am also used to High shipping charges and duty. Any time I buy anything from the states I have to bend over and take it up the **s. If I lived in the States, I would be making more money and have a Phat car. But I guess I will just pay twice what everything is worth
So please somebody help me out .
I even said please. I know you guys have probably heard this song and dance before, But I live in Canada. So I am used to a shitty unfair dollar value, I am also used to High shipping charges and duty. Any time I buy anything from the states I have to bend over and take it up the **s. If I lived in the States, I would be making more money and have a Phat car. But I guess I will just pay twice what everything is worth
But it's true... I remember when I could get an OBDII to I adapter for $100 local, now most of those greedy bastards want $200 more or less (shame I didn't need it then) for the same piece of plastic and wire !! But it is true... if there is $ to be made... often times, most won't tell you how to do it for cheeper that they'll sell.
Good luck
Good luck
Here you go...
http://www.jdmfan.com/technical/perf...obd1/index.inc
I hear ya man i had to buy one used. but anyways im here to help. check out my site too while you slealing my stuff.
www.clutorrtechracing.com
ok here they are
OBD2A http://CLUTORRTECH.homestead.com/fil..._version_A.doc
OBD2B http://CLUTORRTECH.homestead.com/fil..._version_B.doc
If it looks all jacked up just scrole down a bit and you will see the good stuff.
Whos da man. hope this helps
[Modified by turboex, 10:37 PM 5/26/2002]
ok here they are
you spend 4 hrs and make your own.
someone posted a while back the parts list and the company that sells the connectors. I just got finished yesterday rewiring a B version to an A version. Had a short between 2 leads due to a sharp piece of solder that pierced the heatshrink! Was flipping out till some voice in my head told me to check for shorts.
good luck making one, its tedious work. If I ever had to buy one I would pay the $250 to not have to go through with the wiring and have one made and tested.
awesome turboex!!!
gruvy....the time spent too me is well worth the money saved!
i live in canada.so.if i buy it here the harness is.... 575 canadian(before taxes)!
thats outrageous!!!! if i got it shipped it would stil be 400 canadian.
i already have the parts(cost me.. $10 from a buddy..its legit too) all i need to do is wire it up.
i can spend the money saved on a nice greddy egt gauge!
and stil have some moeny over for some beer and a lotto ticket
[Modified by SiRkid, 2:12 AM 5/27/2002]
thats outrageous!!!! if i got it shipped it would stil be 400 canadian.i already have the parts(cost me.. $10 from a buddy..its legit too) all i need to do is wire it up.
i will!
this is soo great. im so happy i can do this now!
i was like crap.im gonna have to buy one(cause the webpage is not for my ecu.)
but you guys come to the rescue!
ttt
you certain the word doc(either one) is the right wiring set up????? will i need to add a resistor to my 00 SI?
[Modified by SiRkid, 11:56 PM 6/16/2002]
you certain the word doc(either one) is the right wiring set up????? will i need to add a resistor to my 00 SI? [Modified by SiRkid, 11:56 PM 6/16/2002]
Well im glad you guys like them! i ended up paying for mine as the clips i had were for obd2a and not obd2a. so if anyone wants to buy them make an offer. LOL
have fun its alot of work
i do make the harnesses and i want to say that the obd2(99-00 civic and 00-01 integra) to obd1 chart is wrong. you can not run a 00-01 integra on a harness made for a 99-00 civic. the fuel pump wire is not in the same location. the reason its not in the same location is due to the emobilization chip in the ecu and the key. the fuel wire is a16 on the 99-00 civic and the emob wire for the 00-01 integra is a16. best of luck.
ps also wanted to say that u dont have to use a 1k ohm resistor from the +12v to the icm. you can just connect the tach wire to the icm and your done.
[Modified by b16aeg6, 12:10 AM 6/18/2002]
if you have a 00-01 integra u move the wire a15 on your car's harness to a16 this will connect the fuel pump wire correctly. if you have a 99-00 civic the diagram is correct. best of luck.
I bought a harness from c-speed racing.com and they say that there odb2 -odb 1 civic harness work together with 00-01 integras...i currently am running it on my car which is a 00 gsr and the harness i'm using is a 99-00 civic....
