Mini-Me fun!
Old Jun 29, 2006 | 10:24 PM
CRX-Noob's Avatar
Default Mini-Me fun!
I have a 91 CRX DX with a ZC block and a Vtec Head. Im having problems with low rpms, the car stuggles for fuel. But once the car hits higher rpms it runs fine. Now i have the OEM Fuel pump freshly installed. Upgrading the fuel pump shouldnt be an issue? My manfold sensor plug is not compatible with my stock sensor plug. The stock sensor has two prongs and the new manifold has three prongs. What do i have to do to get this sensor hooked up?
Thanks.
Old Jun 29, 2006 | 10:42 PM
eye.ha8.u's Avatar
Default Re: Mini-Me fun! (CRX-Noob)
Struggles for fuel, sounds like your timing is off.
Old Jun 29, 2006 | 10:46 PM
CRX-Noob's Avatar
Default Re: Mini-Me fun! (JayDeeEmm)
the timing can be off and still run fine in the higher RPMS?
Old Jun 29, 2006 | 10:52 PM
eye.ha8.u's Avatar
Yes
Old Jun 30, 2006 | 03:57 AM
CRX-Noob's Avatar
now for the Mini-me i need a special cam gear? How would i fix the timing issue?
Thanks
Old Jun 30, 2006 | 06:39 AM
89shithatch's Avatar
youll need a cam gear if the mini me swap is done a a d15 motor.
Old Jun 30, 2006 | 08:12 AM
vegaskurt's Avatar
Default Re: (89shithatch)
Advance your distributor (turn towards the firewall) and give it another shot. It would be wise to invest in a timing gun.
Old Jun 30, 2006 | 12:41 PM
CRX-Noob's Avatar
Default Re: (vegaskurt)
the block is a SOHC ZC (non-Vtec). I need to connect my Manifold Map Sensor. Does anyone have any ideas on to how i can get the sensor connected?
Thanks
Old Jun 30, 2006 | 01:06 PM
CRX-Noob's Avatar
Default Re: (CRX-Noob)
Anyone?
Old Jul 2, 2006 | 11:13 AM
90hatchblack's Avatar
hey i have a sohc zc in my 90 si hatch i have a v-tec head out of a ej 95 civic ex and i know i need a distro and i think the intake manifold bolts up right
but i need to know how to switch from obd-0 to obd-1 and how to wire the distro
and what else do i need ? thanks
Old Jul 2, 2006 | 11:32 AM
HondaPartsHero's Avatar
Technical Hero
just use the factory MAP sensor that is in your car already. Just run a vacuum line from the intake manifold (you may have to "T" another line) to it and you're done.
mushmash
May 21, 2018 08:05 PM
LinkJ
Honda CR-V & Element
13
Jan 11, 2013 12:35 AM
1990 SI EF
Jul 20, 2010 10:00 AM
hoopty8211
Feb 21, 2006 10:28 AM
