help!!!
aight...i got a jdm d15b in my ef with a obd0 wiring harness with a LS ecu...i cant pop v-tec...what ecu can i use that is obd0? or do i have to switch everything to obd1?
thanks,
bobby
thanks,
bobby
"pop vtec" huh? lol. If you want to stay OBD0, you only option is to use a PR3 or PW0 ecu. Just a warning, as these ecus look for 2 O2 sensors, so unless you are running two, you'll have a check engine light. The motor may also run on the rich side since these ecus were meant for DOHC VTEC motors. Converting to OBD1 isn't such a big pain these days since there are so many people making OBD0 to OBD1 conversion harnesses. It's almost a plug and play affair.
