question for 2point6, does the euro r im use the egr.
Old Jun 29, 2006 | 06:20 PM
EZ$$EF's Avatar
Default question for 2point6, does the euro r im use the egr.
does it actually hook up to the manifold. or do you just hook up the sensor and block the valve off. because thats what i did with the skunk2 manifold (blocked the egr) and it throws cel. so now i can not pass emmissions and i actually got an extension which will soon run out to fix my cel problem. i've reset the ecu (pulled fuse) drove around and went into emmissions and it failed. I've erased the codes with an obd2 and that didn't work. but i don't want to buy this manifold to do the same thing as i've done with the skunk 2. I need a confirmed response that the euro r im will not throw a cel. PLEASE
Old Jun 29, 2006 | 06:32 PM
98vtec's Avatar
moderator emeritus
Default Re: question for 2point6, does the euro r im use the egr. (EZ$$EF)
http://blacktrax.net/btp_euror_im.html
Old Jun 30, 2006 | 04:29 AM
bluedlude's Avatar
if you are OBDII then blocking off the EGR is always going to throw a code. damn emissions.
elips0id
Apr 16, 2005 08:30 AM
jeffchaisi
Mar 23, 2005 10:28 PM
bauer778
Mar 8, 2005 06:11 AM
whttyper1998
Mar 7, 2002 07:07 PM
